2wd manifold and abs unit
escort mk4 cossy 4x4
i have a 2wd manifold fitted to the escos with external wastegate conversion.but its very close to the abs unit,less than 10mm.is this going to cause me any problems?i can just about get the heat sheild between them.
i can use heat wrap no probs. the escos is standard sierra under the bonnet,so other people must have had the same problem. iam looking for a bias pedal box,as that would remove the problem.
Si B
12-09-2015 06:49 AM
dojj
28
11-09-2015 10:00 PM
