turbos
turbos
i need to get a new turbo, so far i have managed to figure out i need a T34 with .63 housing as i am wanting to run grey n go for about 380bhp
but that is all i know so far
are all T34's the same i can buy any i find for sale are are they different spec one or some better than others etc?
help me im clueless
help me im clueless
Former Sponsor
ello pliz...
in general T34 s are the same...
just depends if someone has added to the spec of the turbo
ie: cut back blades, 360 bearing kit, external wastegate, antin lag etc etc,....
the possiblilities to upgrade a turbo are available, but as said, generally they re pretty much the same
carl
carl
Originally Posted by G.B Turbo Solutions
ello pliz...
carl
carl
Former Sponsor
maram shaft £600 ish
360 bearing kit £130
plus he price of turbo
thats pretty much it,..then theres extra's like external wastegate different material ex housing, but normal .63 housing can cope no probs with extra heat...all depends what is wanted, but the above is the basic upgrade needed for anti lag
carl
carl
come again
what housing does my standard T3 have?
was thinking this, cos i have seen a few T34's for sale with .48 housing, but i want a .63
so i'd have to buy a .63 in would i not?
ah sorry tabetha, i should worded that a bit better
i didn't mean what would it cost in labour, i meant how much do .63 housings cost?
yeah i know i wont get it any cheaper
just means i can broaden my searches if its easy/cheap to change over cos then i can buy one with a .48 n change it over
but i dont really know what am talking about tho
take it its not really worth while to do that?
A T34 and T3 core is the same ie the inner part between the TURBINE and COMPRESSOR HOUSING.
Std turbine housing on a T3 cossie is .48, you would just need a .63 then bolt straight on, these come off of amongst others a escy large turbo model.
To then get to T34 full spec you can have your COMPRESSOR HOUSING MACHINED out which also saves on the cost of buying new hoses, as escy T34 comp housing is bigger outer diametre where hose from air filter bolts.
If you look down the throat of a T34 off a escy cos you will see that it decreases a lot in diametre internally.
I was happy with my T34.48.
Former Sponsor
what would it cost to change a housing on a turbo from .48 to a .63?
Change it yourself the core is the same on a T34 as a T3, so just unbolt old bolt on new.
2 totally different things there tabby....
carl
Former Sponsor
just seen this bit....
£300 for brand new garrett item to your door
£399 from TT
carl
yup....wont be under as much stress as say a stage 1 4x4 t3 or similar...
if you get me,..
i know what i mean..
if you get me,..
off i trundle to shell out 300 sheets.....
£300 for a T35...
used i assume...otherwise you can get me 10
so got chatting on saturday after me rolling road and a deal was done, complete with 2wd manifold of course.....
fook me....
thats much cheapness....
The operator said it was the turbo holding it back and to upgrade to a bigger one, and repplace the 4x4 manifold with a 2wd one.
I have always been told the CORE, ie without wheels and housings is the same for T34 and T3, so you sre saying they are diffrent as I cannot see in the piccies ?
I would have a nice KKK if I had my way, better than garrett anyway ?
Former Sponsor
no tabby....
re read my reply, and look at the bit in great big bold black lettering....
cahwood asked how much for a .63 housing (exhaust housing)
and you said the cores were the same.....
2 different things....hence my reply....
anyway...
you are dead right about the cores being the same...
same from the smallest of the small...(standard rst) right up to T38...
if it start T3 etct etc....they all the same bearing housing
carl
anyway...
carl
G.B......I think what tabetha meant was that because all the cores are the same the exhaust housings do just bolt on!!
Former Sponsor
i have just re read, and double re read the replies from when cahwood asked..
and imo the reply was confusing...
hence, the next reply from cahwood....
but yes...
tabby cat is correct, and in a long winded way, i have reitterated that...
now kids,....dont work too hard, otherwise you will lose the power of being able to read....
like me....
carl
come again
but yes...
like me....
carl
JK12
33
26-04-2021 12:09 PM
