is it normal for a cossie breather to spit oil out on boost
Old 19-04-2007, 07:14 PM
Roosie
500bhp Cosworth in making
Roosie's Avatar
Default is it normal for a cossie breather to spit oil out on boost
i havent got no hose that goes to my airfilter to turbo yet so the airfilter is bolted thgere as it has the std breather outlet going into it when i was botingit up the road and come back i had a little oil coming out the filter as abvoiusly its coming out breather or would it be different if i had the turbo all connected to filter with a hose?
Old 19-04-2007, 07:59 PM
Best thing to do with your is to get a breather on it, and do away with the PCV one on it at the moment, use catch tank or drain down to offside block for return.
Old 19-04-2007, 08:03 PM
Rick
Rick's Avatar
Yes mate, the way you have it it is normal. As long as there's not gallons of the stuff.
Old 19-04-2007, 08:05 PM
col cos1
col cos1's Avatar
as above bailey breather
Old 19-04-2007, 08:20 PM
*Bri.4.b.Cos*
*Bri.4.b.Cos*'s Avatar
Or if you don't like bling, Fosters can and a bit of pipe
Bri.
Old 19-04-2007, 08:29 PM
Roosie
Roosie's Avatar
whats better catch tank or drain back in car
Old 19-04-2007, 08:34 PM
*Bri.4.b.Cos*
Drain back into engine will not require emptying, catch tank will
Bri.
Old 19-04-2007, 09:13 PM
Roosie
Roosie's Avatar
how much am i looking at for a breather with hoses ect if i want to take it back to engine?
also do i need to put a adapter in rocker cover?
mint_s2
02-09-2015 08:58 AM
YODI
30-08-2015 01:12 PM
JoeyBoyden
20
22-08-2015 03:23 PM
JoeyBoyden
18-08-2015 10:52 PM
RsS2daz
14-08-2015 05:26 AM
Quick Reply: is it normal for a cossie breather to spit oil out on boost
