4x4 cosworth oil return pipes on there turbo
Old 18-04-2007, 09:22 PM
Roosie
500bhp Cosworth in making
Roosie's Avatar
Default 4x4 cosworth oil return pipes on there turbo
my t35 turbo return pipe rest against turbo manifold slightly so i cant tighten it right up wonder why my car was smoking from turbo area does anyone elses sit this close or on the manifolk
Old 19-04-2007, 06:36 AM
BEND it then!!
Old 19-04-2007, 06:42 AM
Roosie
Roosie's Avatar
my luck it will snap
Old 19-04-2007, 07:09 AM
Kevin B
Kevin B's Avatar
Mine dont sit that close / touch manifold mate...
Old 19-04-2007, 07:15 AM
Roosie
Roosie's Avatar
i think i might have to twist the front housing a little may help
Old 19-04-2007, 12:33 PM
I'll bend it for you then, or remake, cut reweld etc whatever.
Old 19-04-2007, 12:36 PM
Roosie
Roosie's Avatar
sorted now i turned the housing. cheers
dont fancy doing my lambda plug for me in my exhaust?
Old 19-04-2007, 12:38 PM
Turbosystems
Super Moderator
Turbosystems's Avatar
your turbo core assembly has been incorrectly orientated you need to realine the core on the exhaust turbine housing then realine the compressor
Old 19-04-2007, 12:39 PM
Roosie
Roosie's Avatar
ive done it now mate its cos i had a 2wd t34 and had to change it for 4wd so just had to do a slight adjustment
Old 19-04-2007, 05:59 PM
YES I will be more than happy to weld in your boss for lamda for you!!
big_Rad
15-09-2017 09:36 AM
Bailes1992
16-08-2015 07:14 PM
cossie4x4
14-08-2015 06:29 PM
14-08-2015 07:29 AM
Old ford
31-07-2015 06:50 AM
Quick Reply: 4x4 cosworth oil return pipes on there turbo
