Spacer/DeComp plates- Making and Calculating?
DEYTUKURJERBS
I know they far from ideal, but spacer plates...
Who can make them? Or is it a simple job for any machine shop if you give em a head gasket as a template?
What would they charge you think?
And how do you work out how thick you need? My sums suck at the best of times
1st to 200 without NOS
Re: Spacer/DeComp plates- Making and Calculating?
DEYTUKURJERBS
Originally Posted by GARETH T
Steve you thicko,, it isnt the hardest thing to work out
Early high comp B200E volvo lump.
10.1@1 compression.
88.9mm bore, 80mm stroke.
More like 8:1 (possibly a bit less) is more like what id want.
10.1@1 compression.
Your engine has a swept bore size of 496.57cc which needs 54.5cc above the piston at tdc (unswept) to give 10.11:1C/R . Add 496.57 to 54.5 = 551.07cc then divide this by the 54.5 which gives your c/r. Each 1mm extra thickness gives an aditional 6.2cc... Clear as mud?
Guest
Posts: n/a
10.1@1 compression.
just to help you out steve for future referance
first you need to calculate the non swept volume/chamber volume
cylinder volume (boreXstroke)
-------------------------------------------chamber volume
compression ratio minus 1
now you can work out your displacment ratio,,,,
cylinder volume
--------------------------------=displacment ratio
combustion chamber
the displacemnt ratio is always one more than its compression ratio
thickness of spacer would equal
new disp.ratio - old disp. ratio
----------------------------------------------------X stroke = thickness of plate
new disp.ratio X old disp. ratio
cylinder volume
combustion chamber
DEYTUKURJERBS
ah see, sums, they jus confuse me, lol.
seriously tho, cheers guys
question from the ferriday site, it says...
so the head gasket- between spacer n block, or spacer n head? im guessing block to spacer as its iron-alloy rather than alloy-alloy.
personally im suprised you dont need 2 gaskets
When using a Decompression Plate - only one head gasket must be used. All that is needed to seal the plate is a thin smear of high temperature non-setting sealant around the water & oil galleries between the 2 metal surfaces only.
fit the gasket between the parts with the biggest differential of thermal expansion - eg. if you have iron block, steel spacer and aluminium head, then fit the gasket between the spacer and the head. Headgaskets are designed to accomodate the expansion movement of the dissimilar materials.
Make sure the mating faces that don't have the gasket are as flat and clean as possible to ensure an intimate face to face surface fit - the sealant effectively then seals the fluid channels, the effect of the sealant round the cylinders is largely academic.
fitting a gasket both sides of the plate will almost certainly lead to trouble, there's too much compressible material and it will allow the potential for the plate to move around too much.
It is common practice to fit a shim plate to a skimmed head, the thickness is much less but principle is the same, only one gasket and sealant the other side.
If the mating faces are flat and clean enough, there is nowhere for the cylinder pressure to go in practice, the plate behaves like an extension of the block or head.
DEYTUKURJERBS
Originally Posted by Chip-3Door
Just get johnsons to make you up a 3-4mm head gasket
http://www.google.co.uk/search?hl=en&q=johnsons&meta=
*** Sierra RS Custard ***
PS
quick google search came up with these details:
G. R. Johnson Gaskets
2 Verity Street, East Bierly, Bradford, Yorkshire, BD4 6PN, UK Map
Tel: +44 (0) 1274 682298
I dont have their number with me to check its the same company, but im pretty confident it is.
DEYTUKURJERBS
You sure thats the place Chip?
Ill be ringing Bradford so I dont want to end up ringing the wrong person and it get all "Yeah ill hook you up maayyed, give me your credit card details and ill do it mint maayyed" and then all my money dissapears
nipper.1
Ford KUGA
12
30-05-2022 07:39 PM
TPM961
15-01-2018 10:50 AM
SMILER258
28-09-2015 09:04 AM
