power,wot u think now with graph....
Old 20-04-2007, 10:29 AM
  #41
crazycage
crazycage's Avatar
Originally Posted by NEWTON
Originally Posted by Christian and Beccy
That's as laggy as my GT30!! WTF?
why you think it so laggy? i cant understand it the turbo is a t3,55trim 360 bearing and .48 rear housing,its pissed me off mate it hit 246 atw but jamie said it was detin at top end,i thought i had my combination of bit right,the cam is a kent cvh 37....i need some help to change the spec,i want 300bhp cheers
if that was @ the wheels then thats really good,what was the flywheel fig ??
Old 20-04-2007, 10:31 AM
  #42
NEWTON
NEWTON's Avatar
is that At the wheels or Fly? as 246 ATW is impressive
that was at the wheels but we couldnt let it run at that
Old 20-04-2007, 10:33 AM
  #43
NEWTON
NEWTON's Avatar
fly wheel fig is on the graph
  #44
NEWTON
NEWTON's Avatar
Originally Posted by GARETH T
what compression ratio is the engine?
8.5-1
Old 20-04-2007, 10:35 AM
  #45
GARETH T
GARETH T's Avatar
it you measure it at 8.5:! or you goign off what the pistons was ment to be?
Old 20-04-2007, 10:38 AM
  #46
NEWTON
NEWTON's Avatar
it got measured,using standard comp accurlite forged pistons with machine work to the head
Old 20-04-2007, 10:41 AM
  #47
Christian and Beccy
#1 in Spelling Club
Christian and Beccy's Avatar
Any idea how they measured RPM?? I just wonder if it's a pick-up discrepancy? Does seem awfully laggy.
Old 20-04-2007, 10:51 AM
  #48
NEWTON
NEWTON's Avatar
god knows mate this maping lark is double dutch to me.but it needs to be sorted,how come the power ends at 5,770 rpm?
Old 20-04-2007, 03:27 PM
  #49
pee vee
pee vee's Avatar
yeah... why does the power seem to Drop off completely at about 5700
RPM on just about all RS turbo engines ive seen graphs for?
also Why does it make 106 lb/ft at less than 1500 rpm
and yet it makes less than 40 at about 1600 rpm???
not a dig or anything mate. just wondering
good result really for a T3.. apart from the lag issue
Old 20-04-2007, 04:01 PM
  #50
crazycage
crazycage's Avatar
thats just a spike in the graph, dont no why they always drop off like that
Old 20-04-2007, 05:36 PM
  #51
NEWTON
NEWTON's Avatar
dont no myself mate,but i want more power,i think ill change the cam to a newman spec with solid lifters,and change the turbo,god no;s to what spec tho
Old 20-04-2007, 06:11 PM
  #52
SapphyMike
SapphyMike's Avatar
Originally Posted by Garage19
Now you have got to ask yourself is that value for money when i can get 250bhp out of a stock 2ltr zetec with a £100 headgasket.
How do you manage that?
Old 20-04-2007, 06:14 PM
  #53
NEWTON
NEWTON's Avatar
id like to know as well???
Old 20-04-2007, 06:54 PM
  #54
Garage19
Garage19's Avatar
By bolting on a turbo.
My point is why spend all that cash on the CVH when you could get that power from a standard 2ltr zetec with the addition of the right turbo and and some aftermarket management.
Old 20-04-2007, 07:00 PM
  #55
NEWTON
NEWTON's Avatar
it still going to cost more than £100.00 eg management , injectors,mapping ,turbo...it all mounts up
Old 20-04-2007, 07:44 PM
  #56
crazycage
crazycage's Avatar
i would have your engine mate and not a poxy £100 zetec with god no's what mileage,it would cost just as much to do do a zetec right,i'd like to see a zetec with just a£100 headgasket deal with 22psi
  #57
tonyk
tonyk's Avatar
It all comes down to what each owner considers value for money. If you add up the cost people spend on these cars it really is scary.
Example:
All Steel Bottom end £2000
big valve cylinder head £500
Stg 3 turbo, T34 turbo etc...£300-£800
Air Filter Kit £60
Exhaust System £250-£400
Tubular Manifold £500-£1000
Management Software £200-£2500
Large Intercooler £300-£500
Decent Gearbox £500+
bigger brake setup £200-£1000
Suspension Kit £300-£800
Fixing Faults with Car, rust, bushes, sensors, etc.. £100-£1000's
Labour For Fittting and mapping £ Dont think about it.
Old 20-04-2007, 07:52 PM
  #58
Rs1
Rs1's Avatar
Seems a fair enough graph final figure but it seems it not making full boost very early....for a t3 anyway That explains the tailing off though, you need a bigger turbo mate
Old 20-04-2007, 10:47 PM
  #59
NEWTON
NEWTON's Avatar
thats what i thought
Old 20-04-2007, 10:48 PM
  #60
NEWTON
NEWTON's Avatar
ill have one very soon
Old 21-04-2007, 06:53 AM
  #61
Garage19
Garage19's Avatar
I'm factoring the management and turbo out of the equasion as you would, and have had to, buy them anyway.
Just sheerly talking about the amount you have spent on the actual engine.
Old 21-04-2007, 07:10 AM
  #62
Garage19
Garage19's Avatar
So you pick one with a known mileage. Have you ever actually stripped down a 100k zetec?? It will be in much better shape than a 100k CVH.
As for doing it right... why is it not right if it is making the same horsepower for £1900 less? If mapped correctly it will be just as reliable. With the right turbo and due to its extra capacity it doesn't have to deal with 22psi to make the power!
Old 21-04-2007, 09:54 AM
  #63
Turbocabbie
Top Cab !!
Turbocabbie's Avatar
Old 21-04-2007, 07:11 PM
  #64
JamboRS
focus rs 1672
JamboRS's Avatar
o rly
Old 21-04-2007, 07:41 PM
  #65
NEWTON
NEWTON's Avatar
back to the thread......any help in turbo spec and cam spec would be good
mark94
Ford Mondeo Including ST
10-10-2023 06:52 PM
phil51
Ford Focus Diesel
02-10-2015 01:00 PM
Iain Mac
30-09-2015 09:39 PM
dojj
29-09-2015 10:32 PM
deathrider666
28-09-2015 06:12 PM
Quick Reply: power,wot u think now with graph....
