Pectel monitor boost reading
Monte Geek
How accurate is it? as it reads exactly 0.2bar more then my Stack boost gauge all the time.
My understanding is the Pectel Monitor info comes directly from the Map sensor via the ECU so infact the fueling is matched to that?
So which one do I go by?
Monte Geek
I've not tried another map sensor no, the Stack uses its own map sensor which is feed by a pipe which is about 2metres long, would it be losing pressure along this pipe then? I could shorten the pipe and extend the wires to the gauge, would that be better?
Mark RS
12-10-2015 06:01 AM
07-10-2015 12:56 PM
Russ Payne
25-09-2015 08:29 PM
