4x4 saph bottom arms
the little rubber boots on the lower arms on me mota have both split
can you get just new rubber boots and if so how easy for a numpty to put the new ones on ?
plus.............. is that a mot failure if they are split ?
Matt
Matt
theoretically they aren't available seperately, but go to your local factors and get the cheapest balljoints you can get with suitable size boots and swap them over ![Wink](https://passionford.com/forum/images/smilies/icon_wink.gif)
taking the MOT rules to the letter they shouldn't fail if there is no play in the joints, as that is what is specified to test, but in practice they are likely to fail and should be replaced anyway as it will lead to trouble if left.
in the longer run it would be fixed but the mot runs out on the 19th
how easy is it to get the ball joint out of whatever it goes into etc
does the arb have to come out etc ?
Matt
Matt
If you get the size one of these could be ok,save buying complete joints
http://search.ebay.co.uk/search/sear...&fsop=1&fsoo=1
http://cgi.ebay.co.uk/10-Larger-Trac...QQcmdZViewItem ![Wink](https://passionford.com/forum/images/smilies/icon_wink.gif)
Split boot is usually a failure, Im off next week Matt if you need help
thanks very much tony, the only problem is that the car is going to liverpool for a little neatening up of the bodywork and is being mot'd while its there,
will have to see what happens but that ebay link you popped up looks like a winner
what do you need to get the ball joint from the hub ? do you just simply undo a nut and it all comes down etc ?
how do you know if the ball joint is knackered due to lack of grease ?
questions questions lol
Matt
![Clap](https://passionford.com/forum/images/smilies/9c-clap.gif)
Matt
fpmsl
so its a case of in simple terms
A) jack car up
B) remove wheel
C) undo pinch bolt or nut
D) pull bottom arm out
E) check ball joint
F) refit new rubber boot
G) put ball joint back in place tighten up put wheel back on and off the jack ?
Matt
A) jack car up
B) remove wheel
E) check ball joint
Matt
sprung steel round clip ![Top](https://passionford.com/forum/images/smilies/smile011.gif)
Looks like this lol
http://cgi.ebay.co.uk/Ford-Escort-Mk...QQcmdZViewItem
Just carefully take off your own and then replace it back on the new boot.
Pack with a bit of new CV grease if the ball joint is still ok
Looks like this lol
Fudgey
17-09-2015 01:06 PM
truffleshuffle
10-09-2015 09:35 PM
