Zetec Turbo Pistons
Zetec Turbo Pistons
Where (if) can you get new calibra turbo pistons from? anyone know how much they are?
Any other budget pistons?
Is it advisable to use a 2nd hand set if they have limited wear with new rings?
Location: Sudbury Suffolk, Drives: Octavia VRS & XR2i 1800 Zetec track car
Wossner forged pistons do Calibra turbo ones and Zetec turbo (Zetec E up to 1998 from Mondeo, Focus, Fiesta mk3 etc) c/r 8.5:1 difference is Calibra ones are available in slightly different bore sizes JTM can do them for £499 delivered with pins and rings which I think is cheap!
http://www.woessner-kolben.de/english/indexenglish.html http://www.woessner-kolben.de/englis...r-kat-auto.pdf
www.jtechmotorsport.co.uk though don't think the site is working properly
Z
Z
fook they look cheap? have you used these pistons? whats the score with customs tax etc??
was thinking of a real budget build but with correct comp ratio and no de-comp plate, so 500quid out of my budget. what do other peeps use apart from machining the standard zetec pistons?
Cheers fella, not at the mo as i'm still in nz, home in may so will do then unless i change my mind Thanks though bud
I'll join up in a sec, whats your user name on there?
Jonlem Don't ask lol
Occasionally second hand 86.5mm pistons show up. I dont think you will be able to post a wanted advert until you have 50 posts or something so just let me know if you want me to do it.
