t3 rebuild
Team HOTHOT!
I just scrapped a few compressor covers aswell from cosworth TY3 turbos
No specialist tools really, but you will need a 12 sided socket to remove the nose nut - off the top of my head it should be 11mm
and be very carefull, marking everything before you remove it to make sure it goes back in exactly the same place - this will minimise the chance of the turbine shaft + wheels becoming out of balance
bollocks! always the way aint it . anyone else got one they want to throw in my bin? lol
mark the shaft/comp position? as in 12 oclock on both for instance?
Team HOTHOT!
Mark them so you know where they will re-line up and all will be good.
take extra care when removing the bearings etc etc, and you will need a small pair of circlip pliers that compress the circlips
nice one cheers.
what temp paint can i use on the housings/wastegate elbow? nothing bufty just nicer than oily rust colour 800c be enough?
Team HOTHOT!
instead of painting, give the exhaust housing a going over with the wire brush on a drill - brings it up quite nice
Also the most important bit of advice I forgot is - take your time and do not rush
Boost Builder
Depending what you want i can supply basic kit for 40.00 delivered, genuine garrett full kit for 55.00 and add a 360 bearing for 50.00. have plenty rst wheel and covers i think but no cos stuff im willing to sell currently
Boost Builder
T3 Kits contain
1 shaft nut (lht)
1 seal plate gasket
4 Seal plate bolts
1 Compressor cover gasket
2 journal bearings
4 journal circlips
1 front oil seal
1 rear oil seal
1 270 thrust bearing
Full kits contain above plus new bolts clamp tags, lock tags but are genuine garrett
basically if your doing a rebuild for use then basic is fine,if its for cosmetic reasons ie bufty then full kit is best
1 shaft nut (lht)
1 seal plate gasket
4 Seal plate bolts
2 journal bearings
4 journal circlips
1 front oil seal
1 rear oil seal
cool.
you ever done anything with stand alone oil/water systems on turbo's? i dont want to put any more stress on the engine than i have to so been dreaming up a few ideas lol
07-10-2015 12:56 PM
Mc5506
05-10-2015 09:57 PM
