spec for 400+bhp
spec for 400+bhp
what would be needed for 400-450bhp on 4x4 sapph?
a mate has got 350bhp at the mo with greens and T34 with .48 housing?
Originally Posted by pete mcrash
u start by checking the engine and its history.........power is a peice of piss..........but no point if the engine goes bang...........
1 Post
400 can be done on blacks or greys and a t34.63
450 would take a more money as i would be uprating a lot also would need a t38 or sod it and bolt up a T4 PMSL
1 Post
Blacks have better spray patten, dont need fitting kit and generally meant to be a better design, flow rate wise similar so i believe.
Stu does rate the blacks
Football Cwazy
there's a hell of a lot of stuff tbh needed for over 400bhp, especially to be reliable too.
if it's 4x4 i wouldn't advise it anyhow as he WILL break gearboxes very often!!!
i'm currently running around 420bhp on ;
Greys
T38
headwork ( mine is overkill but you'll defo need some porting and maybe a bd14 inlet cam or similar )
WRC head gasket
tbh there's far too much to mention, but it's gonna cost a pretty penny
Greys
T38
WRC head gasket
i've got 4x4 saff just been on rr it made 330 bhp & 400 lbs feet of torque at the wheels , so i think that works out around 400 bhp ish
the spec is
t34 , 63 rear housing
rs500 spec cooler
blacks ( 550 cc )
msd live map , coil pack conversion & closed loop lambda
it peaks around 36 lbs of boost
the engine internals are totaly standard even comp
hope this helps
ps it goes like stink
the spec is
rs500 spec cooler
blacks ( 550 cc )
hope this helps
Sponsor
u just need a healthy engine to run 400 bhp with 55lb black injectors a good headgasket and a t38 as with todays fuel ect you have to bash the shit out of a t34 to get a honest 400bhp
to run a turbo such as a t4 gt30 for 450 then i think you will move into porting head as surge ect will become a prob
the spec is
rs500 spec cooler
blacks ( 550 cc )
MSD live map , coil pack conversion & closed loop lambda
hope this helps
the spec is
rs500 spec cooler
blacks ( 550 cc )
hope this helps
1 Post
dependent on spec a T34 can do 400 no probs, Turbo Dynamics can get 400 from a T34.55 with a GT32 compressor wheel and a bit of fiddling, never mind a .63, imagine 420 possible on a .63, be ringing the bollocks off it though
Sponsor
T38's are available from a few companys all in different specs too iirc
Mine (although not fitted) came from Turbo Technics
Stu at MSD could supply everything your after though
I stand corrected then
I thought I read somewhere that he did, I did read though that Turbo Technics Warranty is excellent as they will cover their turbos even when they are being used on good power engines.
I have no idea if any other manufacturer has that policy or not
1 Post
Turbo Technics were ok, struggled to get info when i needed on a turbo i had, took loads of phone call.
Turbo Dynamics are not only 5 miles down the road but when i phoned them about a turbo that i had bought while on the phone give me a full breakdown of the last rebuild, who built it, parts used, then took turbo down there for freshen up, turned it around in 2 days, gave me advice on best modifications at a later stage, chucked in all new free studs, gaskets, gave discount on pre turbo filter.
I just gone back there to get few bits done to the turbo inc different housing, re position the actuator mounting and put in a turbo hanger plate, bead blasted my supplied housing and the trousers, gave it a once over and i got change out of £50.
Spot on servce, they also emailed me the rebuild sheets with the test results
That is good service on their behalf
I got a second hand TT T38 from a guy I met, it hadn't been used but I wanted to know more so I called TT up and they also told me everything I needed to know, and also Turbo Technics are only 30 mins from where I live so makes sense for me to use them.
I'll find out if the turbo is any good when I actually get my car back so the engine can be fitted
I went for 7.5CR, ported head, bd14's, 83's and a universal T38.
Will see what it makes in about a year should easliy make the right side of 400 though.
WD
WD
Would deffo say in my experience go for a bigger turbo than T34.63
Mine made 406bhp on one,but turbo only lasted 6 months running 35psi peak,that was a 360 degree,staggered seal re-built unit
Greys
T38
WRC head gasket
Greys
T38
WRC head gasket
my cars puting out 415-420bhp at the fly with standard head minus bd14 cams
some one must know rough prices for the following that have purchased them in the past
BD14 cams
T38
Black injectors
WRC head gasket
he has RS500 spec inter cooler.
BD14 cams
T38
Black injectors
WRC head gasket
saff is working!!!...atm
i paid £220 for my mountune 3 layer h/gasket........got my ut t38 second hand for £600.......injectors under £300 defo...........u cant just put a steel h/gasket on..........u need the head skimming and the block decking....every thing must be flat
NIL
stu did the mapping, the engine has only ever had a head gasket and main bearings as far as i'm aware all that was done before i got it
it was nick's from msd so stu might have helped with the engine work not 100 % sure though
