Temp guage problem
Old Apr 3, 2007 | 07:41 PM
KW-rscos's Avatar
KW-rscos
Default Temp guage problem
I have a problem with the temp guage on my escort, it goes straight up to the top when i start the engine, but if i take the earth cable off it drops to zero, what are the possible solutions?
any help much appreciated.
Old Apr 3, 2007 | 08:02 PM
BigErn's Avatar
BigErn
Possibly a fault with the temp gauge itself?
Old Apr 3, 2007 | 08:19 PM
JjCoDeX75's Avatar
JjCoDeX75
Probably a fucked sensor matey, though could be wiring. Basically, the temperature sensor is a variable resistor IIRC. As the temperature increases, it offers more or less (cant remember which way round) resistance, which gives the temp gauge the reading. If it is going off the scale, it sounds kinda like a short.
JJ
Old Apr 4, 2007 | 08:57 AM
Likely sensor fault.
Old Apr 4, 2007 | 09:07 AM
nilrem's Avatar
nilrem
STOP!... Carry on
have you got the polarities the right way round. does the temp guage work like normal when you are driving?
make sure the earth and live havent been mixed, either in the guage or the sensor!
Old Apr 4, 2007 | 09:45 AM
KW-rscos's Avatar
KW-rscos
The sensor is as ford left it, I have a new one to put in when i bought a new thermostat the other week,
as for when im driving, it doesnt move it just shoots straight up then sits there until i either turn of the ignition or disconnect the earth, if its faulty wiring, how far does the wire go?
Old Apr 4, 2007 | 11:39 AM
Twellsie's Avatar
Twellsie
mine did this after blowing the head gasket, canged the sensor and was fine
Old Apr 4, 2007 | 11:41 AM
MOONDUST FRST's Avatar
MOONDUST FRST
Mine was just a dodgy earth when it did it
Smit's Avatar
Smit
The 60ft Launch King
Sure it was the right sensor u changed? Not the Blue ECU one but the stubby one which fits in under the brown and blue ECU sensors?
Old Apr 4, 2007 | 11:43 AM
Smit's Avatar
Smit
P.S they are a total WANKER to change...
Hope you've got small hands!
Old Apr 4, 2007 | 12:33 PM
KW-rscos's Avatar
KW-rscos
I havent changed it yet, but as far as i can see it only has one sensor into the thermostat housing, and the brown earth wire that goes onto the side of the head.
Mark RS
Oct 12, 2015 06:01 AM
DAZZER
Sep 30, 2015 08:43 PM
Russ Payne
Sep 25, 2015 08:29 PM
