Identifying Cossie ECU?
Old 31-03-2007, 06:40 PM
Rodge.
Rodge.'s Avatar
Default Identifying Cossie ECU?
Hi,
I recently bought a 2WD Saff to break for parts for my MK2 Escort.
The car has a 4x4 engine fitted, I am trying to find out whether the ECU and loom has been changed. Is there any way of identifying the different ECU models?
The outside of it is a bit scratched so there isn't really any codes on it.
I have taken the lid off - any easy way to tell from here?
Thanks, Rodge
Old 31-03-2007, 06:50 PM
nellyscossy
nellyscossy's Avatar
WHAT COLOUR IS THE CO ADJUSTER SCREW ON THE FRONT
Old 31-03-2007, 06:52 PM
JjCoDeX75
JjCoDeX75's Avatar
If it has a baby board, then it is a L8 or newer. If not, then it will be a L1 or a L6.
Not definitive, but also, the L6 and earlier have the screw lugs on either side to fix to the upper bracket. They dont use this on the L8s
Post photo
JJ
Old 31-03-2007, 06:56 PM
Alvyn
Alvyn's Avatar
4x4 loom is in 2 parts 2w/d is 1 piece from the ecu? regarding ecu's IF standard form L1's have a yellow co screw at the front L6's have a white screws and the bodies have two locating lugs with holes to in secure into place, L8's have white screws and NO location lugs on body P8 same as L8 but late ones have no CO screw!
Old 31-03-2007, 07:01 PM
Rodge.
Rodge.'s Avatar
Looks like white/Silver (dirty)
Post photo
Thanks, it does have the screw lugs on both sides, can't see a babyboard either.
I'll post a pic in a bit
Old 31-03-2007, 07:12 PM
JjCoDeX75
JjCoDeX75's Avatar
Sounds like it will be an L6 then from the sound of it
JJ
Old 31-03-2007, 07:37 PM
Ditto L6 by the sounds.
Old 31-03-2007, 07:53 PM
Rodge.
Rodge.'s Avatar
mark94
Ford Mondeo Including ST
10-10-2023 06:52 PM
gcfcos
59
06-10-2015 05:04 PM
griffo69
04-10-2015 11:58 AM
XR4
Ford XR Range
01-10-2015 12:46 PM
cossie330
27-09-2015 04:13 PM
Quick Reply: Identifying Cossie ECU?
