Wasted spark problem SHE BLOODY RUNS!!!!!!!!!!!
#161
If your tacho reads as normal you wont need to fit the mod, I took my clocks apart and found they were different to the instructions so I put them back in the car without doing the mod and it is fine.
#162
![Surprised](https://passionford.com/forum/images/smilies/shocked.gif)
![](https://i3.photobucket.com/albums/y52/2wd/div%20bil/xcv001.jpg)
![](https://i3.photobucket.com/albums/y52/2wd/div%20bil/xcv002.jpg)
![](https://i3.photobucket.com/albums/y52/2wd/div%20bil/n001.jpg)
![](https://i3.photobucket.com/albums/y52/2wd/div%20bil/n002.jpg)
![](https://i3.photobucket.com/albums/y52/2wd/div%20bil/n003.jpg)
#165
Originally Posted by Electronic
Still not sorted ???
I guess my offer to come and have a look fell on deaf ears![Wall](https://passionford.com/forum/images/smilies/wall.gif)
no mate i bought a S1 over the weekend as sorted t he electric out on that so havent really had too much time to spend on cossie!
we only have 1 amp warming up so cant be much to look at now!
just thought it would be out of your way to come
#168
More boost Igor!
Originally Posted by Roosie
guys how can i test the phase sensor?
got rr day sunday also ont look good![Sad](https://passionford.com/forum/images/smilies/icon_sad.gif)
Get the dizzy out to make life easy, and measure resistance on the across the connector. Rotate the shaft, and resistance should change when the two ridges pass the sensor.
Gap between phase sensor and the ridges should be between 0.2 and 0.3mm.
#173
Originally Posted by trevCOSS
do all 4 plugs spark when you turn the ign on? could be one of the amps is duffed, Mine also sparks when I turn ign on! often fires whatever is left in the engine, however it still starts fine after this initial little fault
#174
ignore last statement both amps heat up just tried them on my mates car and they work fine!
its got a mind of its own trev one min the plugs will spark against engine but not across the gap and one min they are all dead! this is all on ignition only not turning over then they are all dead
#176
Double check matey - my car on normal coil would not start at all when the phase sensor was replaced and plugged in wrong way around.
JJ
#178
#182
More boost Igor!
The plugs are dumb devices and can only fire if they're given current and voltage...so...you've ruled out the ECU, and the TFI modules. The only thing left is the coil pack and/or leads...
It certainly sounds like a short either on or in something.
#184
my coilpack does hum when ignition is on if that sounds right
#185
Originally Posted by jungleistmassiv
had a thought - did you disconnect the battery? i changed the battery on my birds old fezza a while back, i forgot to re-attach one of the earth leads, did all sorts of strange things :S
could be worth a look!!![Wink](https://passionford.com/forum/images/smilies/icon_wink.gif)
#186
Roosie, if you decide to burn it, then we can burn them together. Mine is detonating for no apparent reason as well!
We can have a nice two-cosworth fire!
JJ
JJ
#189
right back now.
yes the ones in the middle are lives.
the one on the right of the brown plug you've marked should go to pin 21 on the ECU, this the tacho drive.
give me a call if u wish and we can run through all the test again to double check.
Ryan
Ryan
#193
Testing the future
Roosie is your bike still for sale? i am probably coming up to norfolk at the weekend to see my brother the original.
if you've still got the bike, i would like a ride to see what i think. we'll also have a look at your cossie while we're there and bring another wasted spark ecu to try![Top](https://passionford.com/forum/images/smilies/smile011.gif)
https://passionford.com/forum/viewtopic.php?p=3797350
#194
your brother has just been here!
he cant figure it out mind u in all fairness he needs spare parts to test out ect. i think this is a mistery to everyone
#197
Originally Posted by Stu @ M Developments
Still no joy pal?
Unscrew the daughter board and try it in a different position mate, in case the ribbon cable is faulty.![Confused](https://passionford.com/forum/images/smilies/icon_confused.gif)
There was no need to wait for me either, Kenny has been at work, its only me that was away in germany.![Sad](https://passionford.com/forum/images/smilies/icon_sad.gif)
il let Stuart (the original) give a lowdown of what he found as hes more clued up than me.
#198
Yeah it's a weird one.
couldn't see anything obvious, I just happened to be passing but had no parts.
earthing on the car didn't seem brilliant
Stu @MSD, does the chip have pectel comms in it, I could try the IAW monitor...
can try the goonybus ecu when i get a chance
#199
is it mega hassle to throw the dizzy back in and try it off the old system with a different ECU? That would eliminate anything thats not in the ECU/ loom conversion for the wasted spark system if it works ok?
