bhp/torque
Old Mar 30, 2007 | 09:44 AM
Xr3i_Mark's Avatar
Xr3i_Mark
Default bhp/torque
can someone give me a fairly detailed explanation of the difference between bhp and torque please
Old Mar 30, 2007 | 09:51 AM
lead_foot's Avatar
lead_foot
is awesome
What do you want to know? Torque is how hard something is turned whereas horse power is work done.
This may help:
So, let's put this theoretical F1 car on the rolling road.
We wind it up until we have overcome the volumetric and combustion inefficiencies caused by the big valves/big ports/long-duration wide-overlap high-lift cams, and bingo! we've got it "on cam".
Let's plot a torque graph. Obviously crap up to roughly "on cam". Remember this is "strength" we're measuring. Now we're getting a roughly consistent combustion pressure, the stroke is constant, as are the number of cylinders. We would hope to see a flatish line on our graph, up until the point we can't breath enough air in, and combustion pressures drop off. The highest point on this graph is Torque, measured in pounds/feet or newton metres. Most tuners will be more interested in width of the flatish bit of the graph than the peak figure.
Now it's time to measure BHP on our F1 car.
We won't get any serious power til we're in the Torque band, then all hell breaks loose!
Let's Guess and say we're "on cam" at 15,000rpm.
We've got 10 cylinders of 300cc each, running at full efficiency, pushing the crank round with a leverage of whatever, at the rate of (and this is the important bit) 75,000 pulses of power per minute.
Squeeze that pedal up a bit to 16,000rpm (you'll need ear defenders), that is now 80,000 pulses per minute.
At the 18,000rpm redline we're packing 90,000 power pulses per minute!
So the higher we push our peak efficiency up the rev range, we cannot fail to make more BHP, purely because we're getting more power pulses per minute.
Old Mar 30, 2007 | 09:52 AM
Stavros's Avatar
Stavros
DEYTUKURJERBS
And if anyone says "bhp sells cars, torque wins races" and truly believes it, they are cocks
PS- Im rubbish at explaining, so wont try
Xr3i_Mark's Avatar
Xr3i_Mark
just the definitions
Old Mar 30, 2007 | 09:53 AM
lead_foot's Avatar
lead_foot
is awesome
Shit, that's the next thing i was going to say.
PS - I'm rubbish at explaning to so i'll shut up.
Old Mar 30, 2007 | 09:56 AM
lead_foot's Avatar
lead_foot
is awesome
Like:
BHP: 1 hp = 33,000 ftˇpound-forceˇmin−1 = exactly 745.69987158227022 W
and
Torque:
Old Mar 30, 2007 | 10:14 AM
AlexF's Avatar
AlexF
as leadfoot says....
also do a search on here: I've written a fair amount about this before
Old Mar 30, 2007 | 11:11 AM
JjCoDeX75's Avatar
JjCoDeX75
There is quite a good write up on this in the latest Practical Performance Car.
I will try my best....
Basically, Imagine a really stiff wheel on a vertical post. (ie the flywheel)
Now imagine a bar fixed to this wheel in order to turn the wheel that is say one foot long. Now imagine putting one pound of pressure on the bar in an attempt to turn the wheel. This would be one Pound per Foot of pressure (ie 1 lb/ft). So if you applied 10 lbs of weight on the end of the same bar, then you then have 10 lb/ft of load.
Now this is important - note that the above has not yet turned our wheel.
Techincally, that means that no work has been done (sad isnt it!) Even if you struggle with it all day with lots more weight - if it doesnt move, then it is not a measurement of work.
Work is the measurement of how far it moves. If you manage to move one pound 33,000 ft in one minute, then you have acheived work, and more specifically, one Horse Power!.
One Horse Power = moving one pound 33,000 feet.
In an engine, the movement is round and round, rather than in a straight line! As such we talk about revolutions (also known as RPM!)
So now you have the torque from the flywheel, and the amount it moves in a given amount of time frame. This gives you the engine horse power!
Power is a result of torque.
So what is Break Horse Power?
This is simply the torque of an engine measured by a tool called an engine brake. What the machine does is effectively try to stop the engine from turning, and then measures how much effort it takes to slow the engine down. When the engine can no longer accelerate, but also does no longer deccelerate, then you have a reading that provides you with a measurement of the engine torque. The BHP is then a calculation based on the the rest!
Clear as mud!
JJ
Old Mar 30, 2007 | 11:38 AM
Carlsworth's Avatar
Carlsworth
Former Sponsor
there is a white bmw 320 turbo in there somewhere that im sponsoring
Old Mar 30, 2007 | 12:15 PM
4x4's Avatar
4x4
JjCoDeX75
kool
so whats N/m
Old Mar 30, 2007 | 12:59 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Originally Posted by 4x4
so whats N/m
Newton meters.
1lbft is 1.356 NM
Old Mar 30, 2007 | 02:36 PM
AlexF's Avatar
AlexF
newtons and lbft are different units for the same measurement.
like inches and meters are distance.
Alex
Old Mar 30, 2007 | 02:47 PM
JjCoDeX75's Avatar
JjCoDeX75
Would this be the one that he took to pieces to fit M5 Throttle bodys that now no longer works?
If it is, it sounds like quite an impressive conversion - M535i engine into an E30 with a turbo on a custom manifold - Developing good power on low boost!
JJ
Old Mar 30, 2007 | 04:27 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
In real simple terms, torque is how much turning force the crank has, bhp is a combination of how hard it turns and how fast its turning.
Old Mar 30, 2007 | 11:41 PM
alistairolsen's Avatar
alistairolsen
but please will everyone remember that the figure quoted normally are peak values and what actually matters is the area under the graphs!!
Old Mar 30, 2007 | 11:45 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
spot on, though how much it matters is depending how much you value drivability and how widely spaced your gears are.
for pure razzing tits outa a car with closely spaced gears its just whats at the top end of the revs that counts, but on a daily driver thats no fun.
thats why ive never liked highly tuned small n/a engines, unless the car is stupidly light.
Old Mar 31, 2007 | 12:27 AM
Rick's Avatar
Rick
Not really, it's always the integral of the torque curve in the rpm band that is used. Peak is actually irrelevant, but sometimes gives you a clue
29
Jan 22, 2015 04:09 PM
bluntys1rsturbo
Shows & Track Days
May 27, 2013 07:05 AM
Jim Green
30
Aug 17, 2005 09:54 AM
