Electric vs Air to Air
Old 14-09-2004 | 10:52 AM
whitneyd's Avatar
whitneyd
Default Electric vs Air to Air
What is best an eletric boost controller or air to air injectors? Why
Old 14-09-2004 | 10:56 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
air to air - ECU has full control .
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
Look at this tread from a few weeks ago. Will help you decide before a can of worms is opened
https://passionford.com/forum/viewto...819&highlight=
Old 14-09-2004 | 10:57 AM
St3V3_C's Avatar
St3V3_C
Take a look here mate :-
https://passionford.com/forum/viewtopic.php?t=66819
St3V3_C's Avatar
St3V3_C
Old 14-09-2004 | 10:59 AM
CossieRich's Avatar
CossieRich
St3V3_C's Avatar
St3V3_C
I guess this is the best bit of that post
Originally Posted by stu@mdevelopments
Ok,
Electronic boost control is in fact closed loop on "Most" controllers which in many ways makes them BETTER than air injectors.
What they do for the uninitiated is they add a high speed solenoid or air pressure valve into the boost signal line. They then monitor the boost output via an inbuilt map sensor and apply various frequencies to the valve to make the wastegate produce the boost pressure that you asked it to...
IE:
Type 20psi into the controller and she will run just that.. 20psi.
The best part is, if your actuator goes weak, she will STILL run 20psi and if its a cold damp night, she will STILL run 20psi.
Air injectors cannot do this unfortunately and simply pulse the valve at a preset frequency at a preset RPM.
The small downside?
Ive personally yet to see one that can reliably handle 30psi having tested 2 and both failed with large peaks at scary and unpredictable times.
(I do however believe that new units to the market are better in this 2bar+respect but i havent tested one so cant comment)
The other impressive feature is of course the gear selectable/engine speed/overboost selectable boost control, but beware, many of these features require serious wiring and mods to work on a cossie ad they are lacking the digital gear and speed selection outputs of their high tech japanese counterparts.
Major downside for me as a professional?
FAr too easy for morons to twiddle the front mounted "Gain/Volume" control during the heat of the moment race.. destroy the engine and give it back and blame me.
"Honest pal, i didnt touch it.. was just doing 40mph in 5th when the crank fell out without warning"
I hope this helps.
Old 14-09-2004 | 11:03 AM
Jim Galbally's Avatar
Jim Galbally
ambiguous question.
do you mean:
what better, ECU controlled boost control or standalone boost controller
or
what better, air-injector based systems or bleed based systems.
both have pros and cons and there are no definitive answers, just opinions
Old 14-09-2004 | 11:04 AM
foreigneRS's Avatar
foreigneRS
Testing the future
the 2 things are not necessarily comparable.
the air 2 air injectors still need to be controlled somehow, whether by the original ecu or by a boost controller.
or, the original ecu could be programmed to use the type of control valve that comes with a boost controller.
best in terms of what? as mike says, air 2 air can be controlled by the ecu (although so could some other form of valve like the escos amal valve) so could be safer, but boost controllers can (in theory) be installed and setup by anyone without having to reprogram the ecu eeprom.
whitneyd's Avatar
whitneyd
Sorry everyone I didn't see that.
zvhturbo's Avatar
zvhturbo
This may help you decide what Electronic controller to go for.
https://passionford.com/forum/viewto...701&highlight=
Old 14-09-2004 | 11:05 AM
RANJ's Avatar
RANJ
stu
have u used the eboost
Old 14-09-2004 | 11:07 AM
zvhturbo's Avatar
zvhturbo
Originally Posted by RANJ
stu
Have you Ranj??
Are they any good?
CossieRich's Avatar
CossieRich
oi oi ranj. Am goin to get meself one of them e-boost controllers.
Old 14-09-2004 | 11:09 AM
CossieRich's Avatar
CossieRich
zvhturbo. they are very good and can handle over 2 bar, without problems. there are two versions 40psi and 60 psi max.
Old 14-09-2004 | 11:14 AM
whitneyd's Avatar
whitneyd
I'm not to big on the gauge display of the Eboost and besides I'm not boosting to 60psi. If I do than i'll use something else but until then I'll use the Profec B-II.
Old 14-09-2004 | 11:17 AM
RANJ's Avatar
RANJ
agree the eboost aint that pretty, but it does what it says on the box, that it holds extremly well
Old 14-09-2004 | 11:21 AM
whitneyd's Avatar
whitneyd
Of course I don't like the look of Stack gauges either. Maybe I'm just picky.
Old 14-09-2004 | 11:56 AM
CossieRich's Avatar
CossieRich
I dont think u'll eva be bossting at 60 psi either. that's over 4 bar!!!!
01-11-2015 06:53 PM
Brickhouse
14
03-10-2015 07:28 PM
Johnny Knoxville
30-09-2015 07:21 AM
stevecfrst1
30-09-2015 05:18 AM
Russ Payne
25-09-2015 08:29 PM
Quick Reply: Electric vs Air to Air
