whats the difference between a
Old Mar 23, 2007 | 03:39 PM
Bullett's Avatar
Bullett
Default whats the difference between a
big wing sump and a dry sump.may sound thick but i cant find anyone who sells the big wing that has info availble but dry sumps are every where.
Old Mar 23, 2007 | 03:42 PM
Sunil_FiestaRS1800's Avatar
Sunil_FiestaRS1800
from what i understand and im no expert. A big wing sump is bigger capacity than std and has a wing init to keep the oil near the pickup.
A dry sump literally has no oil init hence "dry". The oil is circulated via a pump and stored in a tank somewhere in the bay
Old Mar 23, 2007 | 03:45 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
A big wing sump is just a normal sump with extra capacity. It is called what it is, because it has "wings" welded on to the bottom of it that carry the extra oil .
A dry sump is exactly what it sounds like, there is not oil actually retained in the sump, it is stored in a container located inside the car and is pumped around the engine from this. The benefits of this are a few bhp are gained from a reduction in drag, as the crank is not dragging through a large quantity of oil that it would in a "wet" sump.
Old Mar 23, 2007 | 03:56 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Most production cars have a wet sump oil system. The HowStuffWorks article on car engines shows you where the sump is -- it's the area below the crank shaft. In a wet sump, the oil that you put into the engine is stored beneath the crankshaft in the oil pan. This pan has to be large and deep enough to hold four to six quarts of oil -- think about two 3-liter bottles of soda and you can see that this storage area is pretty big.
In a wet sump, the oil pump sucks oil from the bottom of the oil pan through a tube, and then pumps it to the rest of the engine.
In a dry sump, extra oil is stored in a tank outside the engine rather than in the oil pan. There are at least two oil pumps in a dry sump -- one pulls oil from the sump and sends it to the tank, and the other takes oil from the tank and sends it to lubricate the engine. The minimum amount of oil possible remains in the engine.
Dry sump systems have several important advantages over wet sumps:
Because a dry sump does not need to have an oil pan big enough to hold the oil under the engine, the main mass of the engine can be placed lower in the vehicle. This helps lower the center of gravity and can also help aerodynamics (by allowing a lower hoodline).
The oil capacity of a dry sump can be as big as you want. The tank holding the oil can be placed anywhere on the vehicle.
In a wet sump, turning, braking and acceleration can cause the oil to pool on one side of the engine. This sloshing can dip the crankshaft into the oil as it turns or uncover the pump's pick-up tube.
Excess oil around the crankshaft in a wet sump can get on the shaft and cut horsepower. Some people claim improvements of as much as 15 horsepower by switching to a dry sump.
The disadvantage of the dry sump is the increased weight, complexity and cost from the extra pump and the tank -- but that's a small price to pay for such big benefits!
Why you ask Neil?
Old Mar 23, 2007 | 03:58 PM
Graham S1's Avatar
Graham S1
Does it also help with oil surge?
Old Mar 23, 2007 | 04:08 PM
Bullett's Avatar
Bullett
Sunil_FiestaRS1800
well i thought thats sort of how they work but cant find anywhere that sells them to find info
Old Mar 23, 2007 | 04:19 PM
Bullett's Avatar
Bullett
cheers for the replies people.was trying to figure out if i need a big wing for a 400hp engine or can use the normal sump i have.
i def dont want a dry sump then.but may have to go big wing if needed but dunno what sort of place to buy or what price
Old Mar 23, 2007 | 04:34 PM
Mike Rainbird
Caraholic
If designed correctly yes, as well as the added capacity helps the oil to stay cooler .
Old Mar 23, 2007 | 07:02 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
......ur normal sump/oil is going to get very hot when u rag the car.....u can get a oil cooler for less money.........but i have a big wing sump for the extra capasity aswell as cooling.........if u lose half a litre from abuse,the engine will be better off with a larger resivoir of oil.........p.s.......i got my sump from big Mike R..............
Old Mar 23, 2007 | 07:19 PM
JjCoDeX75's Avatar
JjCoDeX75
Why you ask Neil?
Nice little summary, matey
JJ
wowk
Mar 30, 2021 07:49 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
SMILER258
Sep 28, 2015 09:04 AM
Sp3no
Sep 27, 2015 07:23 PM
little bram
Sep 27, 2015 07:45 AM
