Why would my s1 sit higher at the back???
GASH!
Its got brand new shocks, -40mm springs all around, but sits too high at the rear? about 20mm too high. Would i be better off getting longer springs for the front to bring it up, and should i get shorter for the rear? Is lopping a coil off the rear springs a bit naughty?
Mike
Mike
GASH!
Originally Posted by Hardeep_Singh
my s2 did this, its probably the weight differeance, engine in the front and nothing in the back, but as said its better for traction
Originally Posted by Markb_s1
DO NOT start cutting coils off the springs!
(I was only 17 and it sounded like a good idea at the time)
It looked the dogs b*llox until I tried to drive it. Bottomed out all the time and ripped of the backbox on the first speed ramp I went over. Knocking and shaking around, I felt like I was inside a marraca.
Ended up buying a new suspension set up for it. That was the first and last peice of advise I took form another apprentice
Im sure fwd is meant to handle better with the front lower than the rear. Probably why the kit makes it like that.
I personally think it looks better lower at the front aswell. I hate it when you see pugs which have had the torsion bar dropped to the bottom so its low at the rear and high at the front. Looks proper wank like they have a boot full of bricks
GASH!
Originally Posted by Diamonds
would it not sort itself out when you start driving her about?
GASH!
that dont look as bad. i would leave it and see if they bed themselves in maybe?
pic up some fatties to sit in the back
Braking the weight pitches forward
That looks too low unless you have eccentric top mounts or adjustable TCA's to sort out the camber?
You'll have to ask Rick tho about the rest of it...he'll explain rear castor
rog
30
29-08-2015 11:16 AM
