factory allarms(help needed)
Thankfully not the cossie but ,
The allarm on my Frontera keeps going off all bloody nightt and i cant see why.
I went out and locked the doors with the Key thinking the allarm would be deactivated but it wasnt ,i had to leave the thing open all night .
I cant see why it would be going off
Any suggestions or advice appreciated
standard alarm system i assume? if it's the same as the astra and zafiria which i'm guessing it probably is then it'll most likely be the siren at fault, it uses rechargeable batteries inside, after a while the batteries die which causes he alarm to go off at random.
Allways windy here Lawnsy but that was mu first thought.
Will have to have a look in side the sieren then i presume james?
Do you know if they are a special battery or available from anywhere?
JoeyBoyden
04-01-2024 02:36 PM
paceo
03-02-2016 10:31 AM
borboyous
22-08-2015 11:17 AM
