Rad fan water temp
Monte Geek
I've been informed my version Pectel board has a fan temp switch driver aswell
Going to test it tonight and hopefully my ECU will now control when the fans come on at 80-85 degrees
Testing the future
Monte Geek
Thats what I'm testing tonight. Pin 28 on the hairbrush connector.
Been told its worth checking as I have the fuel pump driver and ALS Mountune Rally board. Will find out later
Monte Geek
I've never done it before, but you just need an earthed switch to the brown and black striped wires, that way they will work even if you don't manually switch them on
Monte Geek
OK bought a 2wd fan switch today (finis 7001614) luckily I had a female plug for this switch from my old Fiesta loom
Wired it up and it works mint! So no more fan worries
Interestingly in answer to my original question. the fan switches had the temps stamped on the side of the switches. 2wd has 75-87degrees stamped on it and 4x4 has 1:- 95 degrees 2:- 100 degrees
Also pin 28 didn't work on my Pectel board. It just made the fan be on constantly.. maybe the Pectel board needs to be programed for it? ie a temp value? I'll ask Ahmed when he looks at the car.
Mark RS
12-10-2015 06:01 AM
