ignition timing
Old Mar 13, 2007 | 09:03 PM
rustyrs's Avatar
rustyrs
Default ignition timing
can a low comp engine run more ignition advance than a standard one?
Old Mar 13, 2007 | 09:26 PM
jammy86's Avatar
jammy86
in theory I suppose so as the rate of combustion should be lower if the gasses are less compressed. You could run into problems with the flame front hitting the piston too early though.
Or am I talking pish?
JAmes.
Old Mar 13, 2007 | 09:33 PM
gurnE's Avatar
gurnE
All other things being equal yes it could
Old Mar 13, 2007 | 09:36 PM
rapidcossie's Avatar
rapidcossie
you can defo run more advance...
Old Mar 13, 2007 | 09:41 PM
rustyrs's Avatar
rustyrs
i set the timing to 12 deg and it was flat on boost so i advanced to 18 and it feels quicker/ smoother,thers no det.its a low comp erst.
Old Mar 13, 2007 | 09:43 PM
rapidcossie
the further the advance the longer the mixture burns = more power
Old Mar 13, 2007 | 11:36 PM
GARETH T's Avatar
GARETH T
no it burns for the same amount of time
you want your peak cylinder pressure to happen at the point in the crank rotation where the lever on the crank is greatest
van_dogg_pavvy
Mar 3, 2016 09:30 AM
xrmalin
Sep 13, 2015 06:52 PM
hopper350
Sep 4, 2015 12:53 AM
Zoggon
Aug 10, 2015 10:39 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
