Avo springs
Avo springs
Hi guys and gals, i have just got myself another saff, 4x4 this time though and the suspension is shocking!, am i right in saying if i put 2wd spec, standard ride height avo spring on it, will the car level out as the back is sitting much to high?
Im in the same boat mate, i dont want the car to look slaggishly low, just want a nice level stance!
Watch this thread too
https://passionford.com/forum/viewtopic.php?t=258127
I am using AVO springs on a 2wd (std road height). These on mine look correct. I can see no reason why they would be different on the 4x4, but check.
I believe that you are correct that the std height of a 2wd is lower than that of a 4x4.
My only observation is that I would not want it significantly lower than std - Ford better at design than others!
JJ
JJ
JJ
JJ
JJ
JJ
JJ
SMILER258
28-09-2015 09:04 AM
