Cossie (4x4) running problem - part deux!
Right its not the phase sensor, plugs, leads, rotor arm or cap!
Changed the firing order to 1342 (from 1243, but made no diff) and I can get it to idle but only on two cylinders. If you remove lead 2 or 3 when running it make no difference but i am getting a spark on both cylinders!
Im guessing ive mucked the timing up in some way
Ive..... set the phase gap to 0.2mm, firing order to 1342, rotor arm pointing at no.1 with cams timed up.
Is number one supposed to point to the far right when re-istalling the dissy though?
This is really starting to get on my tits, please help!
PS - other checks I done - getting fuel from all 4 injectors, cambelt correctly timed.
jason_nike
18-08-2019 10:53 AM
big_Rad
15-09-2017 09:36 AM
kosienutter
31
22-08-2015 09:55 AM
Zoggon
10-08-2015 10:39 AM
CabrioTurbo
01-08-2015 11:04 AM
