wireless help please
Old Mar 9, 2007 | 12:12 PM
RichieST's Avatar
RichieST
Default wireless help please
hi guys and gals
Having trouble with my wireless, basically the router and modem is on a computer in my house, my pc is in my room, connected with a belkin USB wireless adapter, and my mum uses her laptop which has a wireless card built into it.
Basically, I switch my computer on it says connecting to network etc.... It will then say connected, so i open up Internet explorer, and nothing. So i right click the connection box (next to the clock at the bottom of the screen), and click repair. It says disabling wireless adapter, then enabling, connecting to the network, then it freezes when it gets to renewing IP address. If i leave it for a couple of minutes it will say it could not connect to the network.
The only way I can get round it is to restart the computer up to about 5-6 times, until it will eventually work, and be trouble free for the rest of the day!
Anyone have any ideas as to what could be wrong?
Thanks in advance
Rich
Old Mar 9, 2007 | 12:22 PM
dvid's Avatar
dvid
On the laptop try removing all internet connection programs / settings
Then set up a new connection:
Control Panel > internet options > Connections > setup
hit Next, then Next, then choose setup my connection manually > Next
Then choose "connect using a broadband connection that is always on" > Ne xt > finish
Reboot
Try that
Old Mar 9, 2007 | 12:26 PM
RichieST's Avatar
RichieST
ok mate i'll give it a go, but the problem is on my PC, the laptop works fine
I'm at work at the mo, but i'll give it a go
Old Mar 9, 2007 | 01:58 PM
dvid's Avatar
dvid
Same should apply, go into that connections tab an remove them all, set a new one up as above
Are you logging on with the same account that everythign was set up on? (assuming you are using XP)
Old Mar 9, 2007 | 02:04 PM
RichieST's Avatar
RichieST
ok mate thanks Yes I am on XP, and I am using only one account on the computer.
I'll let you know what happens!!
Rich
Old Mar 11, 2007 | 12:02 PM
RichieST's Avatar
RichieST
Well i have tried uninstalling the connections as you said, but when i went to make a new one, it just says you cannot do this as you already have a broadband connection set up
So i re-installed the belkin software and the same is still happening. I'm getting this error message
What does it all mean?!?!
Thrush
Computers, Consoles and I.T.
Oct 19, 2005 03:24 PM
Snowy_Astra
Sep 29, 2005 04:03 PM
Gra
11
Aug 13, 2005 01:45 PM
BigNige
Nov 20, 2004 12:02 AM
Turbo lag
Sep 6, 2004 06:57 PM
