sierra mk2 to mk1 conversion
if you can get the body panels which are harder to get hold of as they are older. Ford do not do most of the panels anymore.
Also the rear quarters are different as the shape of the rear lights are different.
Will need new front wings for a mk1 which are no longer available from ford. Grill, etc.
DEYTUKURJERBS
Originally Posted by BRIGSPORT
i'm pretty sure when converting mk1 rear lights to mk2 the quarter is not changed.
you will need to change
front slam panel and headlight panel
possible crossmember not sure
front wings
bonnet
grill
dont know if the scttle panels are different either
the rar end is different
sure the complete back panel is different and the rear quarers are different for the lights as the 3drf lights are triangualr at the ends and the mk2 isnt
lot of work but can be done
plus what mk2 3dr have you got or do you want to do it a 5 door or saf
front wings
bonnet
grill
Well this conversion is a definate goer. I compared cars at my local scrappy,and the rear lights are a piece of piss. The middle section of the rear lights needs cutting out to make the mk1 light fit,as on the mk1,and the outer mounting holes are in the exact same position. I had the mk1 rear light bolted on to the mk2,and aside from the obvious difference in shape on the rear quarter,they go straight on,the look could be finished with filler,but would be better with steel. And i have seen a p100 with a mk1 front end,so its game on!
Well if the above shell checks out o.k. then it will be problem solved.
But i still need something to bolt my parts to so a cheap mk2 5 door will be the order of the day while i prepare the new shell,so the mk2 to mk1 conversion will be done for,shall we say,research purposes!
Is it a converted lhd then?
Also,who can answer my yb versus v8 weight question?
What V8 are you talking about ? the Rover/TVR engine will probably be around the same weight as a YB the 302 Ford will be a lot heavier.
ark
Adam Graham
06-09-2015 06:04 AM
