People with 400+ bhp (cosworth) 4x4 inlet fitted
Old 06-03-2007, 06:12 PM
radiant red
radiant red's Avatar
Default People with 400+ bhp (cosworth) 4x4 inlet fitted
What inlet manifolds are ppl using?
Im purchasing a 4x4 cover from north york tom as my crappy Swedish one has split!!
Just wondering if i need a spacer to allow sufficiant air flow?
ta
Old 06-03-2007, 06:15 PM
Billabong
Billabong's Avatar
Was it a 'Swedish' one or a cheap copy?
I'm on std EsCos one, but 'O' ringed for a better/more reliable seal.
Old 06-03-2007, 06:16 PM
abdr500
abdr500's Avatar
escort cosworth small turbo inlet good for 500 bhp
Old 06-03-2007, 06:17 PM
radiant red
defo cheap pal,came witht the car apparently the last owner suffered some probs with it
i have a full cometic gasket set
Old 06-03-2007, 06:19 PM
Billabong
Billabong's Avatar
Just noticed your sig - you should be fine with what you're getting. If the spacer makes a difference at your power level, you'd really need a remap too....
Old 06-03-2007, 06:27 PM
radiant red
oh i see,well the car should be more like 450 with the full 34 psi which i WILL run on the drag strip etc.The day of the RR it was hitting around 26 psi.I am aware it will be benaficial lower down witht the standard plenum just need to know if ill be ok running this kinda boost level through a t38.
Old 06-03-2007, 06:32 PM
NEIL A
NEIL A's Avatar
Think the 4x4 cover is good for around 450 , small turbo 500 and rs500 cover 550+.
Old 06-03-2007, 06:33 PM
rapidcossie
rapidcossie's Avatar
its not really the plenum thats the restriction, its the elbow.
As abr500 says the eecv small turbo escort is a cracking inlet.
Mines made 453 ATW using one.
Old 06-03-2007, 06:34 PM
pete mcrash
saff is working!!!...atm
pete mcrash's Avatar
i'm on standard 4x4....
Rhys
Rhys's Avatar
For 400 i used std inlet!
Old 06-03-2007, 06:35 PM
radiant red
So the elbow on the 4x4 cover is restrictive then,sounds like its up to the job so ill bolt it up and see how it goes.
Old 06-03-2007, 06:54 PM
Butch.
Butch.'s Avatar
pete send me your 4x4 inlet cover and i'll get this done to stop the restriction on the elbow
Old 06-03-2007, 07:39 PM
pig
pig's Avatar
mines a small turbo escort cos item on mine
Old 06-03-2007, 07:56 PM
Si B
2Evos & 1 Escort Van :-)
Si B's Avatar
I have a Swedish replica inlet plenum, made to replace an ally one that split a couple of times along the welds (after ballooning up anytime it saw decent boost)
Not had a problem with mine, Doug Stirling also uses the same one on his 568bhp car.
Si
Old 06-03-2007, 07:59 PM
cos47
cos47's Avatar
Si
Top quality these are
Old 06-03-2007, 08:17 PM
Turbo Zetec
Engine Machinist
Turbo Zetec's Avatar
pics of your split please!
Old 06-03-2007, 08:34 PM
col cos1
col cos1's Avatar
i was meant to be getting 1 of these sweedish style ones but it fell through....il get one later in year,think my standard 2wd one is maxed now aswell
Old 07-03-2007, 05:04 PM
YBP
YBP's Avatar
Small turbo escort. Slightly ported just to take the rough off it. 480bhp No spacer of course.
Old 07-03-2007, 06:57 PM
radiant red
cheers butch
gonna pick one up tom and ill get the welding done using the picture you posted
Hey im down your way tomorrow,calling at turbo techinics
Old 07-03-2007, 06:59 PM
radiant red
will do mate,the top weld has split all the way along about 6 inches long
Old 07-03-2007, 07:13 PM
Butch.
Butch.'s Avatar
i'll be round northampton somewhere, what u doin getting your wastegate arm fixed
Old 07-03-2007, 07:22 PM
radiant red
yeah fukin things nearly twisted off
from there im up to scarborough for the 4x4 plenum unless someones got one down there???
oh and a boost hose
Old 07-03-2007, 08:54 PM
Escos Jam
Escos Jam's Avatar
I use an rs500 inlet on mine mate
Old 07-03-2007, 10:56 PM
radiant red
Originally Posted by MAD YUM
This is mine
yeah thats ok i guess
Old 07-03-2007, 11:19 PM
aduz
aduz's Avatar
This is mine
show off
Old 08-03-2007, 08:07 AM
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
That's the problem with some of the copies, they're not fit for purpose . I have seen LOADS of these do the same thing. Not ONE of our proper Swedish ones have failed in any way, shape or form .
Now you know why the copies are "cheap" .
Old 08-03-2007, 08:13 AM
AlexD
Post Miester !
AlexD's Avatar
Might get that mod done on mine then..
Old 08-03-2007, 08:19 AM
Dingy
Dingy's Avatar
Mine is an NMS custom one...
Run's over 700bhp on karl's 3door
Old 08-03-2007, 08:27 AM
....Dingy but Karls isnt a PROVEN 700bhp
Old 08-03-2007, 08:28 AM
CossieRich
Did Someone Mention TUV
CossieRich's Avatar
is that the same 700 bhp that piloted his 3 door to 220 mph
Old 08-03-2007, 08:38 AM
Dingy
Dingy's Avatar
Made over 550 at the wheels mate does that count.....
220mph on the m42 Mint
oops soz, brunters only lads
Old 08-03-2007, 08:45 AM
CossieRich
CossieRich's Avatar
rofl
didnt it have a standard coil on it. 220mph on the m42.
Old 08-03-2007, 08:47 AM
R4N SS
R4N SS's Avatar
mine is on std inlet
Old 08-03-2007, 08:58 AM
Dingy
Dingy's Avatar
rofl
Nope a GRP A item but what has that got to do with it
Dingy
Dingy's Avatar
Mine makes just under 500bhp at 26psi......to 7000rpm...
Old 08-03-2007, 08:59 AM
...even i have to Barry Chuckle at 220mph
Old 08-03-2007, 09:06 AM
CossieRich
CossieRich's Avatar
rofl
A Grp A item with 700 bhp and 220 mph? You think its man enough? Dont think so Dingy
Old 08-03-2007, 09:08 AM
bud-weis
Football Cwazy
bud-weis's Avatar
rofl
it is a weapon mate with his current gearing he reaches the limiter (188mph) by the time mine is just about 145mph ish..... measured on the same stretch of road (which isn't that long!)
it's only because he has no interest in competition that we haven't seen more of it
i wonder if he'll lend it to me for the Pf thrash
Old 08-03-2007, 09:11 AM
CossieRich
CossieRich's Avatar
rofl
Not doubting it is a weapon mate, but 220 and no its nothing to do with being MAD, its just i dont beleive he did it thats all
IF the thrash ever gets going, keep on at Karl night and day to turn up
Quick Reply: People with 400+ bhp (cosworth) 4x4 inlet fitted
