What is involved in....
Doing a ZVH Conversion on an RS Turbo?
Just wondering really, as i have the engine out of mine at the mo and im swaping over to EFI OFAB Managment.
I was looking at the engine thinking to myself... (If i put a 2.0 litre bottom end on this no-one will know because the head stays the same)
Cunning.... Cunning like a Fox, i thought.
So what needs to be done? Is it quite simple or are we talking more of a long thing?
Mucho Gracias Senoirs
Your still going to be limited by the management unless you remap which is going to cost you around 500 quid.
standard rods with skimmed pistons are only safe to use if you dont want to run much boost.
if your usin a 2.0 zetec you will require a sump and oil pick up pipe from a 1.8
you need the water pump plate and blanking plugs
The zvh is not cheap to do properly and you still limited by your management at present, I would much prefer a strong CVH running high boost than a fragile zvh on standard rods.
If your doing it, do it properly... for me personally its CVH or Zetec...nothing inbetween
Tell it like it is! I like it
rsguy
44
29-09-2015 03:29 PM
Fudgey
17-09-2015 01:06 PM
Daisychain
22-08-2015 08:12 PM
