help Alps out....Escos top end
#47
All this talk about top speeds........
Ive been no where near the top speed in mine. Just think what effect a stone would have on the bodywork at those kind of speeds.
Although a good few years ago in my old cav i did a true 155 mph quite a few times without trouble. Wouldnt dare go anywhere near that speed on the road though now after realising how bad it could be if something happened.
I assume all these top speed lovers check there tyres properly for damage, wear and pressures etc before they attemp it.
#49
An Escort Cos with out the rear wing should do over 140 if it's standard. There's a lot of drag/downforce with them on. I remember a mag trying a top speed run without one when they hadn't been out long, I'm sure it did about 4/5 mph more? If anyone remembers what mag it was I may well have it and be able to scan the article?
#52
bud-weis
I think the problem i have with the escort is i ws expecting to much after owning my saph, which imo was a perfect spec for road use. I'm going to go for a 3 door or 500 next then that will satisfy my cosworth need for a while i hope
#53
Originally Posted by bud-weis
just get a saff....150mph comes with absolute ease
Most of the tests new they topped out at about 141 -> 143 on the bowl at Millbrook. They usually reckon about another 4/5 mph on a long straight to come oon top as the tyre scrub on the bowl is high at that speed
#55
#57
Football Cwazy
#58
Limiter in 5th std tyre size, very long runway
circa 155-160ish depending on where my limiter was.... (T34, greens std comp etc) speedo was reading 150 a short while before, but didnt have the balls to keep looking at it
#59
Originally Posted by Redkop
Originally Posted by Red16
speedo will under read with 18's
5-6mph out
#60
5-6mph out
#61
5-6mph out
At a true 70mph the speedo read 78
At a true 120 the speedo read 131
JK12
33
26-04-2021 12:09 PM
