Help me with spec please
Old 10-09-2004 | 12:44 PM
Ima-Racing500's Avatar
Ima-Racing500
Default Help me with spec please
So i got 7.9-1 comp ratio,8 x greens,bd10 cams,grp a size ported head/std valves,eec4 plenum throttle body,WRC inlet(CAM CHOICE IS NOT OPEN FOR DISCUSSION )
SECS S8 ECU
What turbo/intercooler shall i use???????I want 450bhp minimum.
GT30
T4
MD240
MD240 "R"
T38
Old 10-09-2004 | 12:47 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
The MD240 will struggle to achieve 450bhp and the T38 will be very close to it's limit at that power. So best if you tell us what your maximium bhp is that you want to achieve. Also your compression ratio is too high and your cam choice is shit .
Old 10-09-2004 | 12:50 PM
Ima-Racing500
Mike....you run 8-1 do you not and 460????
How do you find the lag with the T4 combo?
JAP CRAP's Avatar
JAP CRAP
Gt30
BD10's :gayflag:
Any intercooler but genuine RS500 which is shite (hey Mike )
Old 10-09-2004 | 12:51 PM
Mike Rainbird
Caraholic
Also a budget would help, as fitting an external wastegated turbo is going to cost several hundred more than one that is internal (due to having to purchase a suitable wastegate / getting Martin to modifiy your manifold or buying a tubular one).
Rs Gus's Avatar
Rs Gus
impreza wrx sti version 8
gt30 with a internal gate phillys
Old 10-09-2004 | 12:52 PM
Ima-Racing500
Mike...you can get a GT30 without the need for external
Old 10-09-2004 | 12:54 PM
Mike Rainbird
Caraholic
Phil,
No I don't run 8:1 . And I have more than that .
What lag ?
Dom,
The genuine RS500 intercooler recorded the HIGHEST reduction in temp of ALL the intercoolers .
Old 10-09-2004 | 12:56 PM
Mike Rainbird
Caraholic
Answer the question - top limit of power?
Old 10-09-2004 | 01:04 PM
Ima-Racing500
500bhp
Old 10-09-2004 | 01:11 PM
Disabled Account's Avatar
Disabled Account
Originally Posted by Ima-Racing500
500bhp
Ditch the BD10's for a start!
End of discussuion
Oh I hate my tuner.....
With the sort of combo you have now, I'd say you'll be knocking on the door of high 19's
Old 10-09-2004 | 01:13 PM
Mike Rainbird
Caraholic
Not sure what the turbine of the GT30 is like in integral format, the GT30 with external wastegate and biggest exhaust housing appears to have the ability on paper to flow 500bhp, but won't know exactly until a few more weeks. Will still require 30-32psi, so again you c/r is way too high for that.
T4 can do it, but needs to run 32psi to do so, so your c/r will be way too high for that.
Best to get a GT35 and run less boost to achieve the power (maybe), but you still may need to lower the c/r.
If it was a car that was going to be used agressively, I would say that a custom intercooler such as the ones on Lee's, Martin's, Sean's, Karl's and Brom's cars would be best. But given your driving style the Radtec racing one would be perfectly acceptable.
The EECIV plenum should be able to flow 500bhp .
Old 10-09-2004 | 01:17 PM
Ima-Racing500
Mark Shead says the GT30 internal WILL do 500bhp..not on my cams though ...Just want the max........so maybe T4 at 28psi will acheive 460 ish.
The MD240 "R" seems the best on paper though.
Old 10-09-2004 | 01:19 PM
Mike Rainbird
Caraholic
Phil,
With my c/r (which is lower than yours), I can only run 1.7 bar held...
My choice would be the GT30.
Stavros's Avatar
Stavros
DEYTUKURJERBS
Comp is toooo high IMO too.
Id use a GT30 minimum for 500bhp, tho i know someone whos recently had their cossie engine dynod at just over 500 on a MD240R, but still, id prefer summat bigger (jus like mike says to you in bed IMA )
Thanks
Steve "Lowest comp GTR engine in the UK" Neophytou
PS- What ARE the numbers (lift and duration) for BD10s anyhow?
PPS- LOL@Dougs sig
Old 10-09-2004 | 01:21 PM
GARETH T's Avatar
GARETH T
i think your compression ratio and power output with it is a little high
Old 10-09-2004 | 01:22 PM
Ima-Racing500
Mike...if you was on my exact spec......WHAT bhp would you go for and what turbo?
Sensible answer please
Old 10-09-2004 | 01:29 PM
JAP CRAP's Avatar
JAP CRAP
You'll have to wait a second Phil. harveys phone is engaged at the moment
Old 10-09-2004 | 01:30 PM
Mike Rainbird
Caraholic
I wouldn't be on your spec, as I would be sensible enough not to dig my heals in about certain aspects of the spec. Cams are cheap enough to change / reprofile, so I would speak to ONE person who I had decided I would take advice from (Mark is talking to you at present , so LISTEN to him ) and see what they thought.
My final advice would be to NOT chase numbers, and go for driveability. This WILL mean cam changes AND lowering the c/r to achieve the figure you want and make the car drive nicely.
I love the way my car drives (and would NEVER go back to the likes of my Sapphire), so I would suggest a GT30 and some short duration cams to get it on boost ASAP. This will mean the car will not be as exciting to drive as your last conversion, but will mean you will probably get more from it.
Old 10-09-2004 | 02:13 PM
Andymancos's Avatar
Andymancos
Why is the c/r such an issue when the Ruud racing cossie was running high comp and 650bhp at 1.7bar ?
Old 10-09-2004 | 02:56 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Do you BELIVE the Ruud Racing c/r?
I know the comp ratio of the mega power norwiegan granada cossie and its VERY low.
IMO most people who claim high comp are lying...
And dont forget running mega octane race fuel ups the safe/worthwhile comp ratio you can have.
Old 10-09-2004 | 02:58 PM
Mike Rainbird
Caraholic
Says who? No-one knows exactly what the c/r is apart from the engine builder, just because someone "claims" high comp, how do you know they aren't leading you up the garden path with disinformation? .
There goes loads of people building high comp engines and blowing them to pieces and the person who started the high comp rumour can have a laugh at your expense, as you try and achieve what he has gained from proper experience and end up getting nowhere .
Old 10-09-2004 | 03:08 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
In the GTR world in the UK they all scoff at the thought of comps lower than 8.5:1, even at MASSIVE power, i cant wait to tell them how low ive gone
But then again they all got 280deg cams and then they wonder why they laggy bags of shit
Its all bullshit, smoke n mirrors, even Mikes just said it, and once one person says it, the rumours spread and spread, without most the people saying it knowing the reason for what they saying, and the rest who say it deliberatley missleading people, lol.
High comp HAS its uses, but not really in a road engine on road fuel with no restrictions due to race regs etc
IMO do what ive done with my car, low comp, low duration, big turbo, big boost, everyones a winner, lol.
Old 10-09-2004 | 05:54 PM
GT2's Avatar
GT2
The answer is racefuel!! On pumpgas 98 octane the power was in the region of 540 bhp at max!! And the car that was rated at 658 hp had a comp of 7:1.
Old 10-09-2004 | 06:08 PM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
Mike: You obviuosly dont agree with Phil's choice of c/r and cams. What would you say his c/r and cam choice should be just out of interest?
Old 10-09-2004 | 06:28 PM
7.2:1 & a pair of MAD cams similar to my old engine, 500brake & 490torque goes well with that combo Phil.
Old 10-09-2004 | 06:50 PM
peteh's Avatar
peteh
Anybody have a website with details of the turbos ima has stated at the top?
NZWINRZ
Ford Focus RS
28-01-2020 09:24 PM
01-11-2015 06:53 PM
Turbo1994
Ford Escort RS Cosworth
17-10-2015 10:32 PM
stevecfrst1
30-09-2015 05:18 AM
IainRS1700T
25-09-2015 06:44 AM
Quick Reply: Help me with spec please
