boost problem
Old Feb 19, 2007 | 06:20 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
Default boost problem
my saff was boosting at a 33psi spike, sunday it stopped ,and now peaks at 27psi.... i tried taking the wastegate actuator hose off ,so the wastegate is closed all the time, this should boost way too much...but still only makes 27psi
what do you reckon?
Old Feb 19, 2007 | 06:23 PM
rapidcossie's Avatar
rapidcossie
stuck wastegate?
boost leak at hose or jub clip?
Old Feb 19, 2007 | 06:26 PM
Stu @ M Developments's Avatar
PassionFords Creator
Big air leak most likely pal.
JTECH James
Passion for Fords!
the wastegate is free, i checked that as i tried to put another meter of preload on the actuator
must be an air leak somewhere? cant be turbo if it makes 27?
Old Feb 19, 2007 | 06:28 PM
JTECH James
Passion for Fords!
seemed poor on fuel today to , must be an air leak...plenum off then!!
thanks guys!
Old Feb 19, 2007 | 06:38 PM
If teh wastegate stuck open it would be laggy as hell.
If it stuck closed it would overboost, not underboost.
Air leak or dying turbo it must be. UNLESS, your amal valve is clogged with shit. Worth a check.
Old Feb 19, 2007 | 06:43 PM
JTECH James
Passion for Fords!
thanks stu.
even if i take the pipe of the actuator, so the amal etc is disconneted and the wastegate is closed at all times it still peaks at 27 , i hope the plenum is leaking... i tightened it the other day, and three bolts were lose (third time its done it!) so its probably split the seal i expect...
Thanks again!
Old Feb 19, 2007 | 06:44 PM
Best of luck pal.
Old Feb 19, 2007 | 08:43 PM
JjCoDeX75's Avatar
JjCoDeX75
Whats your idle doing?
If it is about right, then it is unlikely to be pipe off/split, as this would generally increase the idle speed (think ISCV)
Make sure that all the clips are tight, as I found that in the past when I have had similar problem, it turned out to be one of the jubilee clips on one of the large boost hoses.
Hope this helps
JJ
Old Feb 19, 2007 | 09:19 PM
trevCOSS's Avatar
trevCOSS
his idle has been all over the place, its an air leak. James its an air leak
Old Feb 19, 2007 | 09:22 PM
Alg1k's Avatar
Alg1k
dump vale diaphram split
Old Feb 19, 2007 | 10:21 PM
boosthappy1's Avatar
boosthappy1
I had a similar problem a few weeks ago mate
boost drop, bad fuelling and dodgy idle
turned out to be my inlet plenum gasket that was knackered.
Old Feb 20, 2007 | 06:02 PM
JTECH James
Passion for Fords!
well, thanks for the replies guys!
i made an adaptor today so i could connect my cylinder leakage tester to the outlet boost hose from the turbo...
connected it all up and tested it at 2 bar.. had a 60% loss
the manifold-plenum gasket (or sealer!) had gone on a stretch about 4 inches long
also getting a very small air leak from around the iscv, do these have one seal or two?
mine only has one? it may be leaking because the valve shut ,and when the throttle is open the iscv opens to, so this may stop it leaking?
Old Feb 20, 2007 | 07:48 PM
trevCOSS's Avatar
trevCOSS
glad you found the problem told you it was an air leak
Old Feb 20, 2007 | 08:47 PM
And they have TWO seals.
Old Feb 20, 2007 | 08:51 PM
JTECH James
Passion for Fords!
ahh! where does the second one go then? i have a small one at the bottom.....
thanks guys!
JTECH James
Passion for Fords!
im gonna have 65psi when i fix all the leaks
JK12
33
Apr 26, 2021 12:09 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Marino
Sep 12, 2015 11:10 AM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
markk
Sep 9, 2015 08:11 AM
