any builders/carpenters/joiners on here - carport
getting fed up with the pigeons crapping all over my car, and wanna keep (some of) the weather off my car.
anyone on here know how much to build a car port, work involved, time materials etc
anyone had one built, what did it cost, size etc
many thanks
(piccies good for inspiration too)
many thanks
You need to bolt a wooden beam to the side of the house, add some fencing/posts to the opposite side, with a another beam of wood running across the top of them, then fit the plastic sheets at a angle(so the water runs off) to the tops of the wooden beams !!
Me and my mate re-did his car port, and he has a set of doors on the front but nothing at the back, but his house is not in the open. Make sure the bolts are bolted well into the outside house wall, you could run beams from the house to the posts or fence to help keep the roof on, aslong as its bolted together well and you dont live in an open field it should be ok
Materials 300 ish, using cheap roofing sheats. up to 1300 for 5wall pollycarbonate.
size approx 4 meters wide by 6 meters long
labour depends on putting up posts ie have u got to break up any concrete to put the posts in, do you want to put guttering on it, do you want to dig a soakaway, to dicharge the water into, if its all straight foreward, shouldnt take more than 2-3 days approx. for 2 people, so about 900, labour
here is 1 to check out, like the fact it has no posts
http://cgi.ebay.co.uk/FITTED-carport...QQcmdZViewItem
slammedorion
113
04-10-2012 09:33 PM
V6 Ste
14
11-02-2012 09:58 PM
