shot plasting or acid dip
hello im doing a mk1 fiesta at the min and it has rust in some tight places would it be better to get it shot blasted or acid dipped.If i have it dipped will it kill all the rust.also has any one had there car dipped.I no with shot blasting u cant do the big pannels cause it dents them.Was thinking about getting the car dipped in galv just the bottom so it doesnt rust after i have repaired every thing.Also does any one no were to get it acid dipping in the midlans area thanks
My mk2 shell has just been dipped, the guy doing the shell uses someone around your area so I'll ask who it is.
Seen some shells he has had done before and its quite unreal how clean they get the shells
Dipping is Ł500 for just the dip, add another Ł500+ for protection. Remember the dip will shift any dodgy bits quick like and the shell has to be perfectly prepared before it's dipped or you'll end up with holes all over the place. This one still isn't ready after hours of grinding + welding.
I had mine blasted - like you say, the main panels can't be done as it will distort them, but the biggest problem has been getting all the grit out of the sills and other hard-to-reach places.
Leaving it in isn't an option because it will just be a moisture trap.
Originally Posted by dojj
how does blasting bend panels?
you see them doing it all the time on them yank shows, is european metal thinner then?
That Mark 2 Escort wasn't MYS 351P was it?
I built that car way back in 1982/3 with the Zakspeed arches, but couldn't afford wheels and tyres fat enough to fill the arches!
Then put a piston through the block and sold it to a guy from Ayrshire.
Rod-Tarry
237
18-03-2016 09:13 PM
