Sierra hub
The hub face is the same (the circular bit with the studs in) but the hub carrier is definately different to all other sierras even the XR4x4. It is however, the same as the escort cosworth I believe. Hope this helps.
1st to 200 without NOS
even on XR4x4 late and early hubs varied. The caliper lug off changed, not much only talking a few mm but the later cars also had a different offset disc which I think is related.
I've swapped hubs on mine that has moved the caliper position slightly. either the DOHC ones are different or they change on a particular year (possibly 92)
OCD Victim
All 4x4 cars run different flanges, due to the need for a hole for the driveshaft. 4x4 knuckles are different to 2wd ones as the hole where the tca balljoint goes through is a different diameter as well, to avoid people trying to fit the wrong type.
The hub - as in the round bit with the 4 studs sticking out, is the same on all 4x4 versions of Sierra plus the Escort cosworth
The front bearing carrier though (also known as the knuckle) is different - as the steering arm and brake bracket elements are at different points on non cosworth versions
Hope that clears things up
Resident Wrestling Legend
same as it is on the 2wd cars
the knuckles are the thigns that vary and the xr ones vary on the early 2.8's as well
OCD Victim
OCD Victim
That last photo isn't a 4x4 rear hub as it is 5 stud so most likely from a granada.
Originally Posted by PaulRipley
Ignore the 5 studs and the wideangle lens view making them look bent
RWD Racer
Is this one a 2wd front hub?
And is this a 4x4 rear hub
All share the same part number 6779654
chowfornow
14
05-01-2019 09:01 PM
