what does red oxide do whe spraying?
Old Feb 11, 2007 | 05:53 PM
Roosie's Avatar
Roosie
500bhp Cosworth in making
Default what does red oxide do whe spraying?
whats it for? why do people spray it on cars.
i dont know much about spraying
Old Feb 11, 2007 | 05:59 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Just googled and got this..
I've never actually used it when spraying mind
Benefits
Can be used directly over rusty surfaces.
Special anti-corrosive formulation guards against rust.
Ideal for exterior use - can also be used on interior iron and steel.
Provides a smooth, protective basecoat.
Can be overcoated with most conventional topcoats.
Preparation
Ensure all surfaces are clean, dry and free from dirt, grease and other contaminants.
Bare metal: Ensure any loose or flaking rust is removed by wire brushing. Sand down and wipe clean.
Previously painted surfaces: Remove any flaking or blistered paint/rust. Sand down and wipe clean.
Application
Stir well with a broad stirring stick to the bottom of the can.
Apply 2 coats using a brush suitable for solvent-based paints. Sand down lightly and wipe clean between coats.
Drying time
Touch dry in 2 hours. Overcoat in 6 hours. Drying times will be extended at low temperatures.
Hints
Not suitable for galvanised or non-ferrous metal, eg. aluminium, copper and brass. Use International Special Metals Primer instead.
Old Feb 11, 2007 | 06:03 PM
Roosie's Avatar
Roosie
Benefits
Preparation
Application
Drying time
Hints
thats good enough for me!
Next question
What is Single Pac industrial Anamel used for?
Old Feb 11, 2007 | 06:07 PM
S1's Avatar
S1
Synthetic enamel is usually used on commercial vehicles, tough paint and easy to get a good gloss out the gun, but cannot be compounded/polished. Gun finish is what your stuck with.
Old Feb 11, 2007 | 06:09 PM
Roosie's Avatar
Roosie
ive just been given a 5l tin of black enamel,
was going to spray my inner arches with it as my plastic covers are going to be over it so no one will see.
do u need to primer enamel?
Old Feb 11, 2007 | 06:15 PM
Alan s1's Avatar
Alan s1
Dont be tight and buy a couple of tins of Hammerite Underseal be better the just freash paint
I'll get a pic of my inner arches in a min got to find one
******HEAR YOU GO BEST I CAN DO *******
Old Feb 11, 2007 | 06:25 PM
Roosie's Avatar
Roosie
looks good mate
Old Feb 11, 2007 | 07:29 PM
Alan s1's Avatar
Alan s1
Originally Posted by Roosie
looks good mate
underseal is better then just paint tho
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
rsguy
44
Sep 29, 2015 03:29 PM
