General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
if you look at it from above,there's a circle in the centre of the piston ( the base of the 'bowl') 2wd is about 45mm i 'think' from memory,4x4 is bigger
2wd pistons have drilled holes right through them under the lower ring to feed oil from the oil pump spray bar where as the 4x4 have notches which do not go right through the piston as can be seen in the pic
