escort cos problem. help needed please
Old Sep 8, 2004 | 05:19 PM
Deerhunter's Avatar
Deerhunter
formerly uyo1972
Default escort cos problem. help needed please
hi ,
i was out today driving mouses escort cos,we didnt drive it hard ,we drove for about 8 miles and everything was good,then we stopped at a motorists shop,i parked up,still everything was good,then when i started the engine,it started ok,then the oil pressure reading dropped like a rev counter,and the engine died,then when i tried to start it again,it didnt realy want to start,but when it did,we hed to keep the revs above approx 1500 rpm to stop it cutting out and stalling,we took it the 1/2 mile home slowly, started it as it stalled again trying to park,and there was BLACK smoke from the exhaust,
we let it cool down for 2 hours, and it started first turn of the key, the oil pressure stayed as it should, so i drove it down the road, and as i stopped again to reverse, the oil pressure dropped into the red, (slowly again as if it was a rev counter,)and it died, started a bit rough,and its now sitting outside,
has anyone got any clues to what it might ! be, ie sensors, are there any i can unplug to see if it runs ok,???????????
any help or guidence would be appreciated,
cheers and thanks in advance
dave and mouse
Old Sep 8, 2004 | 05:28 PM
Billabong's Avatar
Billabong
Black smoke - possibly ECT sensor (blue) or MAP sensor (would also indicate why it tried to stall) I had something similar and it was intermittent, and therefore harder to trace, as it all worked perfectly once hooked up to Pectel monitor and @ the tuners
Could also be the main wiring loom plugs giving false readings from the sensors to the ECU if these haven't had any attention.... If when you have the engine running you lift these gently up and down (small movements) and it causes the problem, then check in there for corrosion or broken wires - they really need cutting out and being soldered & heat shruk wrapped.
I would *guess* the oil pressure is falling off as the engine is trying to cut. I assume it has correct oil levels etc?
Old Sep 8, 2004 | 05:34 PM
Stu @ M Developments's Avatar
PassionFords Creator
Does it have a dump valve?
Is it tee'd into the map sensor pipe?
Old Sep 8, 2004 | 05:38 PM
Deerhunter's Avatar
Deerhunter
formerly uyo1972
QUOTE .Could also be the main wiring loom plugs giving false readings from the sensors to the ECU if these haven't had any attention.... If when you have the engine running you lift these gently up and down (small movements) and it causes the problem, then check in there for corrosion or broken wires - they really need cutting out and being soldered & heat shruk wrapped.
_________________
thanks mate,we checked all the wires, and the levels first,thanks for the advice regarding the sensors,
we fitted a k+n induction kit last week, and the cars done about 30 miles since then, and was all good, its also the small turbo engine if this matters to anyone else,
thank you,
Old Sep 8, 2004 | 05:42 PM
Deerhunter's Avatar
Deerhunter
formerly uyo1972
STU,
it does not have a dump valve, the k+n i fitted last week, are the only mods on it
Old Sep 8, 2004 | 06:18 PM
Deerhunter's Avatar
Deerhunter
formerly uyo1972
can anyone else help please real tears
Old Sep 8, 2004 | 06:23 PM
Billabong's Avatar
Billabong
Not too clued up on the small turbo EsCos, but might possibly be worth checking no filter oil has gotten onto the MAF 'wire' in the elbow from the filter......?? It's quite delicate I believe, so be careful when checking it.....
Old Sep 8, 2004 | 06:27 PM
Deerhunter's Avatar
Deerhunter
formerly uyo1972
cheers bill, i will take a look
Old Sep 8, 2004 | 07:21 PM
JamesH's Avatar
JamesH
hope you get it sorted Dave
Old Sep 8, 2004 | 07:28 PM
Deerhunter's Avatar
Deerhunter
formerly uyo1972
cheers james, apparently it did it once a couple 0f weeks ago. so it could be like bill said, a break in a wire, as it didnt have the k+n on then,so we can rule that out i hope.
Old Sep 8, 2004 | 07:33 PM
Lee Reynolds's Avatar
Lee Reynolds
This happened to my Large Turbo escos. Id assume that the oil pressure dropped as the revs died really low....like mine....which was MASS overfuelling. Cause was MAP sensor multi plug(the plug that connects wires to sensor)
Old Sep 8, 2004 | 07:40 PM
Deerhunter's Avatar
Deerhunter
formerly uyo1972
thank you lee, i only know how to maintain my rst, i havent a clue when it comes to cossies, i know the plug you meen, i had unpluged it last week too, when i fitted some bling from N.D,so i will look at ALL these suggestions first thing tomorrow,
regards DAVE
lee, could it be the fact the k+n was fitted in replacement of the std air box,last week, and its not been adjusted in any way, ie fueling and all that.
Old Sep 8, 2004 | 08:19 PM
Deerhunter's Avatar
Deerhunter
formerly uyo1972
does anyone else know,about the induction kit .
cheers
Old Sep 8, 2004 | 08:24 PM
Lee Reynolds
i wouldnt have thought the addition of a K+N would cause so many issues to cause mass overfuelling...specially as the filter lets more AIR in not fuel
CONICIDENTLY.....i had not so long before removed my MAP sensor to polish the mounting bracket. This must have damaged the wires(after all cossie looms are poor). A few days later it cut out! Took ages to trace the problem.
Old Sep 9, 2004 | 08:02 AM
!mouse-oxford!'s Avatar
!mouse-oxford!
Old Sep 11, 2004 | 06:03 PM
!mouse-oxford!
still got this prob any help?
Old Sep 13, 2004 | 07:12 PM
JamesH's Avatar
JamesH
Old Sep 13, 2004 | 08:12 PM
!mouse-oxford!
Originally Posted by smidsy
cheers m8
im going to take it to ford get them to sort it
Old Sep 13, 2004 | 08:19 PM
JamesH's Avatar
JamesH
no probs mousey!
just hope you get it sorted!
kosienutter
31
Aug 22, 2015 09:55 AM
y4n
Aug 17, 2015 12:12 PM
muz
Aug 16, 2015 12:57 PM
druidgetafix
Aug 15, 2015 10:22 AM
col93saphcos
Aug 7, 2015 03:21 PM
