who can fit FRST lump in mk2 2 xr2????
thinkin bout getin a lump for my xr2, but need sumone to fit it for me... just wonderin if anyone does a drive in drive out garage service on here for £££.... ?
T
T
Unless you are a complete tool - just get each car side by side and swap everything over - everything fits and you need only connect up 5 wires from the frst loom into your existing loom.
You will need an external swirlpot or fuel tank with swirl pot/fuel return and a cossie/rst pump and you will need to bastardise an frst system to fit the xr2 floorpan - dont use the xr2 exhaust system its too restrictive.
hth - failing that post on xrtwo.com forums and someone may do it for you if they are nearby - but it really is a case of swapping stuff over which isnt exactly rocket science.
Save yourself some serious labour bills and DIY! Seriously it is really simple - then you can put that saved ££££ into some engine mods or something.
JoeyBoyden
04-01-2024 02:36 PM
kyle_st200
Ford Focus Diesel
21-08-2015 09:28 PM
