WHICH INTERCOOLER
Old Jan 31, 2007 | 10:43 PM
  #41
coszee21's Avatar
coszee21
as far as i knw the bottom end is standard but the group A head gasket and ported and polished head
thnks for the ideas boys keep them comin
cheers
zee
Old Feb 1, 2007 | 01:20 PM
  #42
wildheart's Avatar
wildheart
Originally Posted by wimwerf
Originally Posted by wildheart
Ive got pro alloy on mine but if i was to buy again i would go for radtec!
why...
Lower act's from the radtec and the fact that its thicker core.
Old Feb 1, 2007 | 01:36 PM
  #43
Dingy's Avatar
Dingy
I have been told by someone that has tested hundreds of cossies over the years that the original 500 one produces the best results
PMSL...
Mine was shite...
Custom made radtec item.....its awesome
Old Feb 1, 2007 | 01:48 PM
  #44
CliffRS4's Avatar
CliffRS4
RS 500 Coolers can't be that shit if Rod runs one on his saph which I believe he does
Old Feb 1, 2007 | 01:52 PM
  #45
Dingy's Avatar
Dingy
Rod does top speed runs - air flow at 200mph is what ?
And uses NOS...which instantly cools charge close to zero...
Real test for coolers in on track IMHO
500 one is a used radiator piece of shit
Old Feb 1, 2007 | 01:54 PM
  #46
Dingy's Avatar
Dingy
Don't know of any decent track cars using behr rs500 coolers these days....
Old Feb 1, 2007 | 01:55 PM
  #47
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
PMSL...
Mine was shite...
Dingy,
Look how shit condition the genuine one is in, and look how much smaller it is. Can you really compare the 2 fairly mate?
Old Feb 1, 2007 | 01:57 PM
  #48
Dingy's Avatar
Dingy
rich, comparision...
same day...
80 degree's from 500 one and 27 from radtec one....
Reason the 500 one looks bad cause on my top speed run it blew all the fins out LOL.....
but it was shite before that happened.
Old Feb 1, 2007 | 01:58 PM
  #49
CossieRich's Avatar
CossieRich
Furry muff Ding
ta for the reply
Old Feb 1, 2007 | 03:38 PM
  #50
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
Originally Posted by coszee21
my cossies already doin 360 in the dot on a T3 tested on greens with boast at 25psi peeking at 27psi
ive been told tht if i put greys a remap and a good intercooler i should be nearing 400 i dnt knw if this is true so thts why i asked is this posible
or wut would u lot advise for me to get the cossie doin 400
thnks zee
....why does everybody else need a t34 to get this power then...if ur right then "sound" but i dont think anyone else has heard of 360 out of a t3...nevermind 400....cos i'll sell my t38 and buy one of the little bastards back.....
Old Feb 1, 2007 | 03:44 PM
  #51
Dingy's Avatar
Dingy
It all fairness if the t3 was on race fuel it might make 400....
Pump 97 ron fuel you would be very lucky if a t34 powered car made 400bhp LOL
  #52
coszee21's Avatar
coszee21
i c ur point pete the reason why i say tht is cos my mates cossie runnin a t34 and is doin about the same and we are both baffeld as to why we are both neck and neck but i dnt know but thts why i want to change the turbo and intercooler and wht ever else i have to do 400 if u get my point so any ideas welcome thnks
zee
Old Feb 1, 2007 | 03:51 PM
  #53
Porkie's Avatar
Porkie
I have Pro-Alloy 500 cooler for sale. As fitted to my Sierra now.
make me an offer
Top coolers
Its not quite so clean now... but done less than 2000miles so not that bad!
The Genuine Behr 500 Cooler is also for sale.
  #54
pete mcrash
just done a full rebuild on mine and i wanted 400bhp...i had a t34.48 and was going to get a .63 housing for it but was told i'd be ringing its neck and it wouldn't last (due to the fact i drive like a loon) anyway my mates ut t38 came up and i got that...it powers the car easy and when i get head work done the turbos good for 450bhp
Old Feb 1, 2007 | 03:53 PM
  #55
Porkie's Avatar
Porkie
HE USES NOS!!!!!
Old Feb 1, 2007 | 03:56 PM
  #56
4x4's Avatar
4x4
zee
ur mates prob got a shit setup on a t34
so have you put it on the rollers yourslef or did the previous owner tel you that????
if its true then as someone said earlier, sel the t34 t38 and buy the lil bugger for cheaper
Old Feb 1, 2007 | 06:24 PM
  #57
coszee21's Avatar
coszee21
hmmm iguess hes set up is shit lol
so wut turbo u lot advise me to buy and extras for 400
zee
Old Feb 1, 2007 | 07:23 PM
  #58
rapidcossie's Avatar
rapidcossie
sorry to clarify my previous post..
the comment came from someone who has power tested litteraly(sic) hundreds of cossies.
maybe being held on the rollers is different from track
Old Feb 1, 2007 | 07:41 PM
  #59
RS500/364's Avatar
RS500/364
make me an offer
Top coolers
pm the prices
Old Feb 1, 2007 | 07:46 PM
  #60
Mark Shead's Avatar
Mark Shead
Yes Rod runs a stock 500 one and the nos jets are after the air temp sensor as they are mounted in the intake runners and the airtemp sensor is in the elbow so we can still monitor the air before the Nos and it does not have airtemp issues.
Mark
Old Feb 1, 2007 | 08:02 PM
  #61
Porkie's Avatar
Porkie
Mark
Fairplay if thats the case.
why is that then Mark as I know you are a normally a fan of BIG boost or is Rods Turbos now so big that you run lowish boost and a load of NOS??
If its a trade secret then no worries if you do not want to divulge.
Did the old touring cars and thunder saloons running 2.5 bar on T4's used to struggle with charge temps Tony??
Old Feb 1, 2007 | 08:04 PM
  #62
rapidcossie
Rod runs WI to help combat charge temps AFAIK
Old Feb 1, 2007 | 08:16 PM
  #63
Porkie's Avatar
Porkie
So do most people... prevention is better than the cure Euan
Water injection just helps you not LOOSE as much power as you would if the ECU has to start retarding the ignition... as you probably know mate, water taking up space in the combustion chamber is not good. You want air and fuel... I think
Old Feb 1, 2007 | 08:17 PM
  #64
Mark Shead's Avatar
Mark Shead
Mark
I would always run at 2.5bar never run lower that would make it slower we run a nice water injection set up and attention to detail helps
Mark
Old Feb 1, 2007 | 08:21 PM
  #65
rapidcossie
We have seen very promising results with my new cooler so far and with no water cooling problems. (on roolers only so far)
should be able to hold a charge temp below 30 at the end of the runway
Marks WI set ups seem to work as his engines are the proof but AVA have tested WI many times and you ALWAYS lost power when the WI is on.
  #66
Porkie's Avatar
Porkie
so without WI you would have charge temp issues pre NOS you think Mark?
Thanks for answering.
Old Feb 1, 2007 | 08:22 PM
  #67
Porkie's Avatar
Porkie
My point exactly
  #68
carlo's Avatar
carlo
Porkie what intercooler are you using now?
Old Feb 1, 2007 | 08:26 PM
  #69
Mark Shead's Avatar
Mark Shead
We never see more than 40c thoughout the whole topspeed run, Without it most we have seen 50c.
Making the most of heat rejection materials and ducting helps.
Mark
Old Feb 1, 2007 | 08:34 PM
  #70
Porkie's Avatar
Porkie
Nov 1, 2015 06:53 PM
Fudgey
21
Sep 30, 2015 06:19 PM
