What causes cossie exhaust flames
(apart from a flamer kit!)
I love seeing cars spit out the odd flame or two (my dad's Westfield for example ) but don't want a chavy flamer kit.
Obviously its when they overfuel but it is only a certain spec / set-up that causes this?
Re: What causes cossie exhaust flames
Oi there's nothing chavy about flamer kits, they produce the desired effect
Luciano
It's the fact that input values to the ECU are time-averaged, so that it takes a certain amount of time for the high boost and open throttle readings to settle out, hence it takes a small time for the ECU to cut back the fuel on overrun IMO.
Either that or the map is just not very good?
Neil.
Neil.
I see. Am I likely to get an flames spitting out the back of my stage 1 cossie? I imagined it was only the big power cars that do it.
Re: flames
Originally Posted by charlie luciano
Originally Posted by cossie4is dad
Mine does it but i wish it didn't
Steve.
Steve.
Why? flame spitting cossies look phat bruv and its a fucking great detterent for tail gaters
Luciano
And all that fuel im wasting
Steve.
It Wasnt Me!
Re: flames
Steve.
Steve.
Luciano
Steve.
That's alright you've only got two years on me age wise and just think cossie's blast nuff un-burnt fuel out the tail pipe why let it go to waste light it and have some fun
Luciano
Take it a 150mph blast down the motorway for a min or 2, get the exhaust hot....then let it roll down the gears on overunn (at night) an u'll see
Blimey. Sounds like I might get a flame or two then
I'm 33 but still like seeing the sight of a cossie spitting out the odd flame or two
mine used to spit massive flames all the time after Mark had mapped it.
Doesnt spit any flames at all since it was mapped by Alan @AVA.
must be someting in the map
A leaking exhaust manifold also used to cos big flames.
14000+ post superhero
ive been told mine does but ive no idea why or if its good or bad.looks good though especially when its coming from the exhaust of my 16 year old 'estate' car thats just over taken you
flames
All this from a man who knocks Fords but has the heart of one is his crout estate
Hello Fuzzy hows it going geez?
Luciano
My car used to do it on b roads without a flamer when it was stage 1, but only occasionally when giving it real horse and lifting from full throttle then reopening the throttle.
Really fast and bright flashes, not the drawn out flames you get from a flamer kit.
It's now on a MSD 803 0.63A/R T34 chip with Closed Loop fuelling and it does it like mad on gearchanges (with a flamer )
Neil.
Neil.
Did Someone Mention TUV
My stage 3 setup done it using an ahmed chip and my greys setup using a Stu chip also does. Big lingering flames that stay hanging out the back of the tailpipe for 20 secs some times. When the exhaust is proper hot and big boost gear changes and over run in 5th a lot
Re: flames
Luciano
Luciano
Football Cwazy
Originally Posted by JTECHSAFF
not if its closed loop, they have a fuel cut off on over run conditions
MELTDOWN!!!
MELTDOWN!!!
am i talking dog mess???
Originally Posted by frosty
who cares...looks awesome no matter what causes it m8 don't u think.....see u at the pod eh......
Re: flames
Steve.
Steve.
Luciano
Steve.
if that was me in the F40 i know it would probably be enough for me to floor it again straight after hearing the bangs, just imagine the feeling
1 Post
my old stg 1 4x4 saph (with a ahmed chip) used to throw flames out when it was hot ,
but ive never seen my old stg 3 MSD chip escos with the coilpack pop a flame..
