dog,straight cut,sequential gearbox differences
Old Jan 27, 2007 | 08:56 PM
leecavturbo's Avatar
leecavturbo
Default dog,straight cut,sequential gearbox differences
whats the difference, correct terminology for each box type and how it operates i.e full throttle no clutch gearchanges?
can a full throttle no clutch gearchange work on a transversly mounted engine/gearbox arrangement?
Old Jan 27, 2007 | 10:27 PM
gearboxman's Avatar
gearboxman
Lee, for all of the explanations you require, I really need to SHOW you the differences.
Call in
Old Jan 27, 2007 | 10:58 PM
GARETH T's Avatar
GARETH T
this is a gearbox fitted with straight cut gears (and dog engagent BTW) as you can see the gears in the gearbox are cut straight as apossed to
helical gears which are cut at an angle to the shaft!
helical gears place a thrust loading onto the shafts/bearings due to the gears trying to pull/push themself appart! remember that any wasted energy is a waste of power (from the engine)
straight cut gears dont place a thrust loading on the bearing/shafts but they do come at a price! noise
when talking dog in bearbox terms it can either mean dog leg first meaning that first is where 2nd gear normally is on the gear selector (e30 M3's are like this)
or dog engagment gears
as you can see on the faces of these gears there are small drive "dogs" so when selecting between gears these dogs are what engage's the next gear unlike:
syncromesh gear engagment (brass bits) these allow the gear to be selected to match the speed needed before dropping into gear (all standard production cars are like this) and syncro gears shouldnt be rushed (quick shifts a bad idea?)
dog gears will just "bang" in allowing increased gearchange speed, but of cause at the expense of noise and high wear rates
sequential gearbox selection is when you change gear by either pushing or pulling the gearstick (like a motorbike)
this can be done with a barrel on a rathet moving the selector rods!
Old Jan 27, 2007 | 11:00 PM
GARETH T's Avatar
GARETH T
just found this,, it shows a gear being selected with its gear selector fork, and once the gear is selected the shaft starts turning
Old Jan 27, 2007 | 11:09 PM
leecavturbo
Call in
can a transverse engine/box be a pull/push box to change gear ?
Old Jan 27, 2007 | 11:11 PM
GARETH T's Avatar
GARETH T
Call in
can a transverse engine/box be a dog pull/push box to change gear ?
i dont know of a cheap way of doing it! quaife sell a sequential FWD gearbox, but it isnt cheap,, and i know in the early days,, it broke,,,,ALOT
Old Jan 27, 2007 | 11:44 PM
Rick's Avatar
Rick
still does. race box, for race rules - ie no torque.
Old Jan 28, 2007 | 07:59 AM
Tony Ryan's Avatar
Tony Ryan
most of the Gearbox manufacturers produce ranges of FWD Sequential boxes, ive sold 5 or 6 so far this year !! Theres no cheap way of doing it tho and an absolute waste of time in a road car ,
Old Jan 28, 2007 | 08:16 AM
dovboy's Avatar
dovboy
what gearbox did the rs500 touringcars have in them ? it looks like a clutch in h-pattern gearbox,but what kind?
Old Jan 28, 2007 | 08:23 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
I dont think he wants a FWD one, he is probably after a transverse 4wd one?
Good find on the pictures gareth, so much easier to explain with piccys than without!
Old Jan 28, 2007 | 09:55 AM
racer's Avatar
racer
Hi Dovboy, the Group "A" RS500's used a Getrag 5 speed with a dogleg 1st gear position.
Gareth T gives an excellent explanation on gear design, the other reason for helical gears is that the gear tooth is longer and therefore can last longer, take more power, for the given space in the gearbox.
Andy
Old Jan 28, 2007 | 10:17 AM
Rs1's Avatar
Rs1
Call in
I'm pretty sure Simons evo is like this, looks brutal to change gear though
Old Jan 28, 2007 | 10:24 AM
wes's Avatar
wes
You can convert H pattern to sequential operation, ikeya in japan do them and i think is what Simon used on his last evo, not sure about the new one.
http://www.ikeya-f.co.jp/en/index.html
Old Jan 28, 2007 | 10:27 AM
wes's Avatar
wes
Default Re: dog,straight cut,sequential gearbox differences
You need to lift the throttle slightly to do clutchless changes, or fit a microswitch to the gear lever that cuts the ignition when you pull it.
Old Jan 28, 2007 | 11:14 AM
GARETH T's Avatar
GARETH T
with a dog engagment gearbox you can do clutchless up changes, but there not much point, it can wear the dogs alot faster
Old Jan 28, 2007 | 11:19 AM
markk's Avatar
markk
there is a lot of point !! thats what its for pal
Old Jan 28, 2007 | 11:21 AM
GARETH T's Avatar
GARETH T
what i mean is,, your just lowering the life of the gearbox! what for? a tiny tiny improvement in stage time?
Old Jan 28, 2007 | 11:32 AM
Tony Ryan's Avatar
Tony Ryan
Gareth , a quicker gearchange is the most economical "tweek" that you can make , it costs virtually nothing if you look after the box and service it regularily . Imagine an engine or suspension upgrade to make up the same time !
Andy's correct the old RS 500's use a Getrag Gearbox , basically a BMW motorsport box with a longer bell housing , im sticking one back in my car until my X-trac box is ready .
I currently have a New Hewland 6 speed transverse 4wd box on my website , needs a case but spanking otherwise !
Old Jan 28, 2007 | 11:43 AM
GARETH T's Avatar
GARETH T
but whats the gear change difference between using a clutch and not using a clutch on a dog box? they are great to smash through though
Old Jan 28, 2007 | 12:47 PM
Mad Matt's Avatar
Mad Matt
Rally nut
Prices plz
Old Jan 28, 2007 | 12:56 PM
leecavturbo
website tony? i know it would be a huge cost i.e 6-7k+
Old Jan 28, 2007 | 01:09 PM
Mark_1's Avatar
Mark_1
well if you are busy breaking with the left foot it is great to have the option to not clutch.
Old Jan 28, 2007 | 01:43 PM
GARETH T's Avatar
GARETH T
you noramlly only left foot brake when your foot is on the throttle, i dont change when the foots on the throttle
Old Jan 28, 2007 | 02:09 PM
Tony Ryan's Avatar
Tony Ryan
At the bottom of my sig , cheaper than that too , lol.
Old Jan 28, 2007 | 02:13 PM
GARETH T's Avatar
GARETH T
i was searching for your site aswell tony and didnt think to look at your profile or www bit
Old Jan 28, 2007 | 04:21 PM
markk's Avatar
markk
by the time you have actually made the leg movement and your hand is already on the gearlever, you have already changed gear before the clutch has chance to disengage and re-engage that then gives the gearbox problems and to its driven gear speeds and can lead to fluffed
shifts , though i would always shift down in any of quaifes dog boxes with the clutch, other quality doggers dont need the clutch !
Old Jan 28, 2007 | 04:52 PM
GARETH T's Avatar
GARETH T
my mates quaife dogger has blown up more times than its done miles
Old Jan 28, 2007 | 04:57 PM
markk's Avatar
markk
ive had good service from mine, had it serviced regular though, and new bits fitted as and when, the quaife are the lowest of the low, when you look at the tooth profiles compared to and FFD(hewland cut, WOW !!! no wonder they charge what they charge, and and 20 times better
Old Jan 28, 2007 | 05:14 PM
GARETH T's Avatar
GARETH T
mark what box have you got in your car?
Old Jan 28, 2007 | 05:20 PM
markk's Avatar
markk
at the moment a quaife big tooth whle the 4wd system is being proven to be reliable ! the box is the easy bit, its everything forward of that.
Old Jan 28, 2007 | 05:21 PM
GARETH T's Avatar
GARETH T
cool
Old Jan 28, 2007 | 06:42 PM
Tony Ryan's Avatar
Tony Ryan
It will do ! Quaife use a Male and female Dog system instead of a decent dog ring , means the Gears wear out very quickly , on a proper box you can replace the dog rings , Quaifes invariably require Gears ! And their customer service is legendary
Old Jan 28, 2007 | 06:49 PM
GARETH T's Avatar
GARETH T
my friends been on to there "good" customer services a few times
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
van_dogg_pavvy
Mar 3, 2016 09:30 AM
xrmalin
Sep 13, 2015 06:52 PM
hopper350
Sep 4, 2015 12:53 AM
Bailes1992
Sep 3, 2015 02:17 PM
