removed head on the cossy ..follow on from other post
took head off and there no visual crack to the block or head the gasket looks fine to but head bolts are not genuine ones..but there is a scratch on the face of the head and gasket might of been when installed
puddy
yes the middel ones felt losser l and it was number 2 cylinder that was getting water in i know this is my problem ..so this time i will be using what i should have used before 4 layer wrc gasket and cosworth head bolts
Originally Posted by abdr500
Chunk.
you anal cant spend any more money at it
![Content](https://passionford.com/forum/images/smilies/content.gif)
SECS
thats what i all ways do but it didnt over heat or blow the gasket but will skim if needed
could my head bolts have been the problem as there the 10.9 ones with the littel scratch on the head i might be in luck buy changing the gasket and genuin bolts
di you use " dummy studs " to locate the head when you dropped it back on ? If you didn't the heads mover around a lot and can damage the gasket !
Ive just binned a head that had gone porous , you can see lots of little pin pricks all over the head face, smoked like a coont and filled up cylinder no. 3 , thought it was a cracked bore ( again ) but luckily not
Turbosystems
i know it will but if it doesnt need a skim it wount get one but if it does it will get one i am going to use a 4 layer wrc gasket from mountune so that will ad to a thick ness as i was using a comitc gasket befor plus i am all ready low comp
Turbosystems
if you keep skimming your head every time you take it apart eventualy the gasket will be thicker than your head
there is a min head thickness.
what ever your comp is now low or otherwise it will raise it.
The long stud conversion strengthens the block and reduces bore distortion associated with clamping the head from the top of the block
CabrioTurbo
01-08-2015 11:04 AM
