t34 what else
26-01-2007, 10:03 PM
Back in black!
t34 what else
Right I have just won a t34 on ebay is there anything else that i will need
to do when i swap it over with the t3
engine is already stage 3
Ahmed Bayjoo 330 chip
green inj
3 bar map sensor
500 cooler
etc etc
also what sort of boost should i run?
and what sort of bhp should i expect
http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWN:IT&ih=015
26-01-2007, 10:08 PM
you may also need a new chip mate to run the t34
as the fuel map will be different.
26-01-2007, 10:45 PM
run it at 1.7 bar get a re map does it come with the actuator braket as this is often made if you need one i have on Ł10 its yours
26-01-2007, 10:48 PM
if your stage three chip is for a T3 you will need a t34 chip!
a nice intercooler is a good move aswell
26-01-2007, 11:11 PM
Back in black!
got a 500 size intercooler
already got the bracket on. thanks anyway
what sort of money should i be looking to pay for a chip and whos is the best chip?
26-01-2007, 11:15 PM
Matt Baxter
best go to your tunner is your car 2wd or 4x4 as i have a chip t34 green 3 bar 500 cooler but its for a l8 4x4
26-01-2007, 11:17 PM
phone msd monday (is he open on sunday?) they'll sort you out
26-01-2007, 11:36 PM
Back in black!
Quote:
mines a 2wd mate
27-01-2007, 12:08 AM
Go straight to MSD,
His reputation is not without good reason
JJ
27-01-2007, 07:46 AM
Back in black!
Quote:
Originally Posted by JjCoDeX75
Go straight to MSD,
JJ
what should i be paying for this?
27-01-2007, 08:45 AM
i got my t34 greens chip etc from msd think it was Ł150 may be different price now tho as was quite a while back
27-01-2007, 09:04 AM
Back in black!
will it be a plug and play or will need to get it set up again
27-01-2007, 09:35 AM
they are just plug in mate but would advise to get it checked over etc before giving it some abuse
27-01-2007, 11:53 AM
You need to modify the daughterboard a bit,nothing major
27-01-2007, 04:21 PM
C**t
Amazing to think, then when a mate was upgrading to a T34, Woodford and PJ both said the same chip does both.....
So I threw it in the corner and fitted a proper ecu instead
Although its shocking to think "tuners" are giving out that sort of advice. Fuelling with the chip in, was bordering on dangerous IMO at only 24psi.
Cosnada
07-01-2016 05:30 PM
Russ Payne
25-09-2015 08:29 PM
28
08-09-2015 07:10 PM
