ANOTHER PROBLEM PLEASE HELP !!!! NOW DONE WITH MORE PICS !
Old Jan 23, 2007 | 08:54 PM
Tony Rs's Avatar
Tony Rs
Ebony black Sapph Cos
Default ANOTHER PROBLEM PLEASE HELP !!!! NOW DONE WITH MORE PICS !
i was just changing the rear springs on my 4x4 sapphire cosworth and when fitting the rear beam back on (just released it) the big rubber bush just popped out of place now this has stopped me from finishing the rear end and im gutted i tryed everything to fit the bush back on but it just wont really gutted and battered (hands cut to fook) does anyone have any ideas on getting this damn bush back in ?????????????
all help much appriciated
tony
got the rear beam bush back in now and ive taken some pics of the rear lowered then tomorrow ill be doing the front
its a phone pics so sorry about the quality
now with front lowered
this is how it was before
Old Jan 23, 2007 | 09:46 PM
RSCossieGaz's Avatar
RSCossieGaz
sorry tony i cant help you .....................but thought i would give you a bump to the top
Old Jan 23, 2007 | 10:20 PM
Iain Mac's Avatar
Iain Mac
Do you mean the big one that goes on the end of the beam, with the main mounting bolt passing through it, or one of the ones on the trailing arm?
If it is the beam, I think the technique is to lube it up and then use a trolley jack and the cars weight to pop it in, but I'd guess there must be something wrong for it to pop out in the first palce - they are pretty tight when fitted.
Sorry I can't be more help.
Old Jan 23, 2007 | 10:27 PM
Lloyd's Avatar
Lloyd
escort mk4 cossy 4x4
as said use a trolly jack and plenty of grease to refit the main beam bush,it shouldnt have just fallen out,these are usually mega tight fit.
Old Jan 23, 2007 | 10:30 PM
The Youth.'s Avatar
The Youth.
as said lots of lube and also stick a piece of wood between the beam and the chassis so the bush has room to pop into
steve
Old Jan 23, 2007 | 11:02 PM
Tony Rs's Avatar
Tony Rs
yep its the big bush on the beam when i was trying to line up the big bolt to the chassis i used a trolley jack to lift the beam up but i think i went a bit too much with the jack and the metal insert in the bush must have leant on the chassis too much and it poped out thanks a lot for the advise chaps ill give it a go tomorrow
Old Jan 24, 2007 | 05:38 AM
dojj's Avatar
dojj
Resident Wrestling Legend
lube it up but make sure the inside of the beam where it sits is smooth, you might be best off doing a bit of wet and dry on the insides before greasing it all up
if you jack the bush directing into the beam it shuold line everything up, and if it still doesn't go in with the wieght of teh car ontop of it, getting inside and sitting down sometimes does the trick
Old Jan 24, 2007 | 06:26 AM
KSA-Cossie's Avatar
KSA-Cossie
Good luck tony,looking forward to seeing it lowered m8.
Old Jan 24, 2007 | 11:54 AM
Tony Rs's Avatar
Tony Rs
cheers everyone for the ideas ill get some pics up when its done
Old Jan 24, 2007 | 10:37 PM
Tony Rs's Avatar
Tony Rs
up
Old Jan 25, 2007 | 02:07 AM
cheeky dog's Avatar
cheeky dog
blak/dark saffs are the daddys. get some good quality pics up deffo
Old Jan 25, 2007 | 08:08 AM
RSCossieGaz
how fucking low
Old Jan 25, 2007 | 06:47 PM
dojj's Avatar
dojj
they look mint
Old Jan 25, 2007 | 07:24 PM
KSA-Cossie's Avatar
KSA-Cossie
Lower than mine anyway tony,looking really
Old Jan 25, 2007 | 09:08 PM
RSCossieGaz
done the fronts yet tony pics please
Old Jan 25, 2007 | 11:15 PM
Tony Rs's Avatar
Tony Rs
done the front and been out feels really solid and smooth wasnt expecting that
well happy with it ill get some pics up in the morning when its daylight
Old Jan 26, 2007 | 12:01 PM
Tony Rs's Avatar
Tony Rs
UP MORE PICS ADDED
Old Jan 26, 2007 | 12:11 PM
COSSIE 1's Avatar
COSSIE 1
looks a1 mate/ like on my eibach spring question, are they 4x4 spec springs? and did u have to roll any arches with the 8x18" rims??..very very nice mate ....will be getting a set of these babies for mine
Old Jan 26, 2007 | 12:13 PM
COMEDY DAN's Avatar
COMEDY DAN
No1 Blower.
Get some quality pics up.
Car looks awesome.
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Sheepdisease
Aug 30, 2015 09:11 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
nick8saff
Aug 16, 2015 05:35 PM
