pinking / detonating etc ????
Hi,
Are pinking and detonation the same thing
Can someone explain what they mean and if there the same or not ? the reason I ask is that when I went for a set up on the rolling road the operator said it was detonating at high revs
Also can you 'hear' the engine pinking or detonating ? if so what sort of sound does it make ?...........its a s2 erst.
cheers, Duncan
cheers, Duncan
Someone correct me but this is what I remember from my college course-
Pinking - When the ignition is too far advanced, the mixture ignites before the piston has got to TDC and is effectively slowing it down - Gives a tinkling sound. If youve ever been in an old Mk Festa 1.1 then you've probably heard it.
Pre-Ignition - Similar to above but generally caused by carbon deposits in the combustion chamber which glow red hot and ignite the mixture early like in pinking.
Detonation - Caused by excessively high combustion chamber temps or pressures. The mixture is exploding rather than burning/expanding in a controlled way. Leads to even high temps and melted pistons etc
PassionFords Creator
PinKing is what us dumb brits converted the American term too. The American term was "PinGing" as thats what it sounds like.. "ping..ping....ping" Typical of us eh? PINKing? WTF
anyone know which one you can hear and what sort of noise it makes ?
Duncan
Top marks
so thats what it sounds like ! Under really heavy accelleration I get a 'crackling' sound coming from the front end of the car, could be a small leak in the exhaust I suppose I take it if your car is detonating you cant hear it ?
Duncan
i was gunna say what is pinging cas i read it in a motorsport magazine when i was in pheonix and fort maybe i had heard people say 'pinking' wrong and that i was deff but then i read it written as that and assumed they were two different things never really understood either lol
