bayjoo stage 1 ecu - fitting?
erm firstly has anyone got any info on the ahmed bayjoo stage 1 chip for the ERST? i know it take the boost limit up to 1 bar but does it adjust anything else?
and secondly kind of depends on the above qu. but can i just switch the ecu's over, fire it up and it will run the same as before correct? just play with the actuator then to raise the boost?
any other things to bear in mind? (planning on running 12psi to begin with and get an ACT guage in there)
ta.
ta.
12 psi should be fine as you are still on the stranded intercooler
You should be ok to swap over the ecu’s, but you may have to make some adjustment to the ignition timing
The fuelling will need to be setup
or you could risk melt down
:cry
Steve
![Surprised](https://passionford.com/forum/images/smilies/shocked.gif)
Steve
Rich, this what you need
I have spent most of the day setting up my mates track car
intercooler works very well
![](http://homepage.ntlworld.com/clark.rs/passion%20ford/intercooler.jpg)
Steve
Steve
The amal valve has most likely been jetted, i.e. the restrictors have had their internal diameters tweaked to set boost levels correctly without over adjusting the actuator.
His a few more picks of the car
The car has been built for track use, anything none essential has been removed
Steve.
![](http://homepage.ntlworld.com/clark.rs/passion%20ford/inside.jpg)
![](http://homepage.ntlworld.com/clark.rs/passion%20ford/enginebay.jpg)
![Banana](https://passionford.com/forum/images/smilies/banana_dance.gif)
Steve.
![](http://homepage.ntlworld.com/clark.rs/passion%20ford/seats.jpg)
big_Rad
15-09-2017 09:36 AM
CabrioTurbo
01-08-2015 11:04 AM
