Delta S4 (vid)
DEYTUKURJERBS
Delta S4 (vid)
http://www.youtube.com/watch?v=lU785z8-2qI
been vids of this S4 hillclimber before, but never seen this nice compilation one before, fucking awesome car
DEYTUKURJERBS
Originally Posted by XR-RS
i tried for ages on friday to find that vid and couldnt, dunno why maybe just missed it
i couldnt for the life of me remember the drivers name, and still cant
Driver is Bruno Ianniello
Stavros - is this related to your own balloon inflator/turbo combination
Noticed that in the early videos of the S4 it doesnt the make the dump valve sound?
I assume the set up was changed but fook me does it sound good
Would have been amazing to see the develop properly
Originally Posted by xr4x4rs
is it supercharged?
sounds so nice
sounds so nice
is it supercharged?
sounds so nice
sounds so nice
DEYTUKURJERBS
is it supercharged?
sounds so nice
sounds so nice
The bypass is used for idle and off/light throttle. You get horrendous pre-throttle boost spikes off throttle if you didnt have a bypass of some sort then, high enough to break summat.
AUSTRIA
Seen this car live at Rechberg in Styria(Austria)
The first event of the FiA - European Hill Climb Championship every year...
I can tell you, live it´s even more awesome to watch and listen to!
"holy sh..." were the first words that came to my mind
DOHC 16 valves total - 4 valves per cylinder
1759 cc (107.341 cu in)
Compression ratio -7.60:1
Fuel system - Ma-We fuel inj.
Aspiration - T & S/Charged
Compressor type - 1 Abarth supercharger & 1 KKK K26 turbocharger
Intercooler -2 air-air
250.00 BHP (184 KW) @ 6750.00 RPM (1985 homlogation cars)
215.00 Ft-Lbs (291.5 NM) @ 4500.00 RPM
480 bhp (358 KW) @ 8400 rpm (1986 works cars)
490 Nm (361 ft lbs) @ 5000 rpm
Officially the most powerful works S4 car produced 550 horsepower (410 kW). Unofficial figures claimed this S4 could accelerate from 0 to 100 km/h on gravel in just 2.5 seconds. Henri Toivonen drove this very car on the 1986 Corsican Rally, where the Finnish driver inexplicably missed a tight left-hand hairpin bend and plunged into a ravine, where the S4's fuel tanks exploded.
Awesome car but many people believe they are more powerful than they actually were, it was the power to weight ratio that made the S4 something special
is it supercharged?
sounds so nice
sounds so nice
DEYTUKURJERBS
is it supercharged?
sounds so nice
sounds so nice
I know for a fact the only vehicles (2 cars and a good few big rig trucks) ive seen with this system (ie turbo blowing thru charger) do not bypass on boost, as it would defy half the reasoning for it. Infact a few of the people laughed when I asked them about that side of things.
All off them had bypasses though, the two cars used adapted external wastegates, and the trucks used something similar but seemingly custom made. All the bypasses were for off throttle and low throttle running.
The one car previously had no bypass at all, but this caused issues due to the throttle being downstream of the supercharger meant there was huge pre throttle boost spikes when he let off the gas, causing extra heat, mega loud whining front the charger as its working hard against a shut throttle, and even a bent throttle plate and split intercooler.
He solved it by adding a second throttle pre supercharger too, but fitting the bypass to be open at light and no throttle made the biggest difference to drivability.
There is a crossover point in the supercharger unit..
http://www.autozine.org/strange_car/..._s4_charge.jpg
oh my mistake i thought i heard of a twin turboed supercharged one,obviously not.
Still fantastic...and regard Henri's crash apparently he was suffering from the flu...my opinion is that an S4 and flu could never mix
DEYTUKURJERBS
It was for off/light throttle running im almost sure (as they need one then for reasons ive explained above), as it serves no purpose bypassing when on boost, lots of downsides to that too.
www.deltaintegrale.it/1/tec/triflux.htm
Zoggon
10-08-2015 10:39 AM
cossie1
34
31-07-2004 10:05 PM
Andy_R
02-06-2004 04:01 PM
