Cosworth engine , would you change....
Basically need some views on this one people as im at a bit off a crossroads to say the least
Now ive bent a valve or two as some of yo may no already , and obviously heads coming off to sort that out , so going to get the head sorted out to a decent spec , again not sure what as yet
Now the questin is would you do the bottom end ? Now didnt have any problems that i know of with it ,accept some piston slap from cold
Now engines a bit of a unknown to me as have not had car that long really and bottom end will be standard i can bet on that for sure , now got a stage 2 t35 turbo , 500 cooler and all the stage 3 stuff and going to be upgrading to light blues and a 044 pump as i have them here to fit once engines sorted ,and also chip to suit my spec
Now could leave bottom end as it is and just get it back together and go from here but was thinking of the long run when i up the power slightly ?
If anyone has any views let me know as it would help me decide on what is best to do
or any simalr scenarios that people may of had
how many miles has the bottom end done?
as any prob with wear will most prob raise thier head when you raise the boost...
if it has done over 50 k miles i would re built for peace of mind....
What ever you deside hope all turns out well.
Football Cwazy
Good advice from Euan above......just look for wear on the bores,if there's a good amount then you can bet your life the rings are letting oil past and raising power will only exaggerate it, on the other hand tired engines can still run for ages and make good power,just tend to smoke and slap a bit
Dunno Rab, maybe a light freshen up but don't go daft. There's no need. I'd suggest just doing the bare essentials depending on how much power you're chasing..
Obviously a full rebuild would be best but if it aint broke...
well my theory is why do thaings by half...
If the head is off ur halfway there, it aint much of a job to get the rest out, so u might as well
If you're intending on keeping it for a long time then what's another 4-6 weeks off the road so you end up with a right good build. Whats Johnny saying about it? Look at his engine, that's made really good results.
Not really mate confident in puting it back together , the head depending on my phone call tomorrow will got to nms or ava but not sure what they offer as yet and prices , as of bottom end then that iL deal with once i decide what im doing , bottom end will most probably be built between ourselves as i have friends that can steer me right hopefully , if i go don that route
Originally Posted by glancy2081
at the very least a would change the rings and shells this wont cost much and is fairly simple to do ![Grin](https://passionford.com/forum/images/smilies/icon_smile.gif)
I defo would hate to be going back into the engine to do something else after doing this
if it was me a would measure the bores for wear, and then if all was ok a would put new piston rings and shells in it only takes a couple of hours if all goes well would even upgrade to arp bolts if not already done
Deffo take a look at it, I took mine apart as the piston rings were shot to find the big end bearings were on the verge of failing, car did have 100K on it though.
At least if you do it you know its been done and don't have too much of a worry if its causing a problem unless you fit it back together incorrectly.
Really al i m looking for is like everyone else a nice healty 330bhp or there abouts , dont wanna be entering daddy thrashes or anything at the moment ![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
Just some piece of mind an to know its done right thats all really , i was prepared for this when i decided to buy another cosworth , but once its back on the road iL be happier than a pig in ******
Not really mate confident in puting it back together , the head depending on my phone call tomorrow will got to nms or ava but not sure what they offer as yet and prices , as of bottom end then that iL deal with once i decide what im doing , bottom end will most probably be built between ourselves as i have friends that can steer me right hopefully , if i go don that route ![Top](https://passionford.com/forum/images/smilies/smile011.gif)
This should give you a rough idea
![](https://passionford.com/forum/images/smilies/burnout.gif)
big_Rad
15-09-2017 09:36 AM
wheelwizardrefurbs
04-08-2015 06:23 PM
