intercooler and pipework boost losses
what amount is typical across intercooler and boost pipework?
i.e i think i have 1.5bar at turbo outlet but 1.2bar at inlet manifold ?
good, bad, average ?
Originally Posted by Pro Alloy Motorsport
witha really well sorted system you should see a gain!
true tho mate
most people notice an increase in boost when fitting a more effcient intercooler...i know i did when i fitted a pro alloy 500 one
He asked what is a typical boost loss in the system, from turbo, to intake manifold.
I would think that 0.3 bar ( 4.4psi ) sounds like a reasonable ( large ) amount. It would be nicer to see that do 1-2psi, or no more than 3psi.
Or is Pro-Alloy saying when you have an efficient system, you will see more boost in the intake manifold, than you do as it exits the turbocharger, before it has met any restrictions to flow entering the engine ???
Originally Posted by Rs1
I was thiking that was a bit backwards myself...turbo is pushing 1.5 bar but the engine see's more, fuck me i want one of those pro alloy coolers ![Top](https://passionford.com/forum/images/smilies/smile011.gif)
My DIY one is a mess
Happily retired
Whats the secret a GT40 inside the Intercooler, thats Clever.
590 BHP/Ton
simple really- cooler air has more oxydgen and therefore more density.
couple that with a lack of restriction through the rev range generally equals more boost!.
we are not talking huge amounts here but when you compare that to a potential loss with a poor set up the difference would be significant.
You can't acheive this on all vehicles due to space/pipework constraints
and we are not the only company that can acheive this!
*** Sierra RS Custard ***
That doesnt make any sense at all.
Cooler Air is indeed desner, that means that the pressure will be LOWER for the same mass of air in the same vessel.
And the % of oxygen doesnt change.
More density means that for any given mass of air you will have LESS pressure in the same vessel though
you see more bost by removing restrictions...
a bigger, freeer flowing intercooler is one way... i got 2 psi.
i also saw a large boost increase after fitting new exhaust... i got 5 psi.
Some seem to think, its possible to get more boost after restrictions, than when measured before them. In effect, you are getting gains for free.
Its kind of impossible....
In a sealed system you put 10psi in before a restriction ( IC+plumbing ), and you get say 15 out ???
If you had an excellent efficient system, you may still get 10psi out. But if you can get more, I say its a miracle.
Originally Posted by Chip-3Door
Pro Alloy Motorsport good welders and fabricators you may be - physicists you clearly are not ![Big Grin](https://passionford.com/forum/images/smilies/icon_mrgreen.gif)
PMSL now that if propper funny
chip is %100 correct
can't argue with physics
Just out of interest Euan, were you running a 3" mongoose into a 4" tailpipe before? What are you running now?
To be fair I think pro-alloy has missed the question somewhat, if you replaced a crappy STD cooler with a high-flowing one, you WOULD see an increase in boost pressure without turning it up .
Lee is talking about pressure drop and losses across his system
Guest
Posts: n/a
Originally Posted by jungleistmassiv
the more efficient the intercooler pipework is, the faster the air will flow, so less pressure.
Same output from turbo + freer flowing cooler = less pressure.
So basically, the more restrictive the flow, the more pressure build up surely?
I thought pro-alloys claim was a bit odd, yes you can gain from a straight swap from poor setup, but not a gain in boost over what the turbo is producing surely?
Lee is talking about pressure drop and losses across his system![Top](https://passionford.com/forum/images/smilies/smile011.gif)
the boost increase half a bar without altering any mechanicals of the engine.
Intercooler that actually works and loses heat from the charge = the pressure will drop
So an intercooler that sees a boost gain would in fact be an inter heater, lol
The key thing here of course is that its not boost you want, its airflow, so if the charge gets cooler and the pressure drops, then thats still good.
Conversely if the pressure drops due to restrictive pipework that means the turbo has to work even harder, and thats bad.
So you could have two intercooler that both see the same boost at the plenum from say 30psi in the compressor housing, but if one is doign so at a lower temperature then thats the better option to go for.
Also,
there needs to be a restriction thro the inter, for it to slow down and cool the charge air.
i think 1-3 psi psi drop is fine, below and above will indicate flow/cooling issues.
Ps, im running a AH fabrications rs500 core, with my own design end tanks, The same core that come out best on the PF test, even tho testing them only to 100mph, will never of showed any of the intercoolers real performances.
or to stop stones and gravel puncturing the core.
Any way, as you most proberly know, the pulser set up is fine at speed for stock power.
But I bet they were making more boost than all the cars that beat them!!!
Just less power of course!
did they use the same inter on WRC then?
Interesting topic this, my boost gauge reads off the plenum at the moment but it would be interesting to see what boost its making before the intercooler!
Mark RS
12-10-2015 06:01 AM
Russ Payne
25-09-2015 08:29 PM
