PC help needed desparately
Old Sep 4, 2004 | 04:30 PM
AJ Escos's Avatar
AJ Escos
Default PC help needed desparately
pc went t**** up last night so have had to start over , i have it running fine except that i cannot get any sound as it says i have no audio device,and i cant seem to sort it any ideas anyone PLEASE
Old Sep 4, 2004 | 05:03 PM
T38Mat's Avatar
T38Mat
You need to find your drivers mate. If its an onboard sound device then the audio jacks will be near to the keyboard/usbs etc and you will need to load the main board cd. If its a seperate card (usually lower down the case)then it will also have a sepertae cd for it (usually saying sound or audio on it)
Load it and that should be jobes a good un.
Good luck
Mat
Old Sep 4, 2004 | 05:05 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Do you have on-board sound (e.g. integrated into motherboard), or, do you have a PCI/ISA card plugged into your motherboard (e.g. soundblaster).
If onboard, check your bios to make sure it's enabled, if not, shutdown, take card out, reboot, shutdown again, plug card back in (make sure it's well seated in the connector) and reboot.
What operating system are you running ???
Old Sep 4, 2004 | 05:08 PM
AJ Escos's Avatar
AJ Escos
thanks m8 looks like its onboard m8, prob why i couldnt find any driver cd for it
Old Sep 4, 2004 | 05:20 PM
frog's Avatar
frog
If you can't find the drivers, try the motherboard manufacturer's web site.
Old Sep 4, 2004 | 05:21 PM
AJ Escos's Avatar
AJ Escos
cheers for the info, all sorted npw
JoeyBoyden
Jan 4, 2024 02:36 PM
jessie_rs
11
Jun 3, 2019 04:57 PM
borboyous
Aug 22, 2015 11:17 AM
col93saphcos
Aug 7, 2015 03:21 PM
