Boost Controller
Old Jan 5, 2007 | 11:47 PM
big_wig_074's Avatar
big_wig_074
can u not just use less throttle on your right foot?
Old Jan 6, 2007 | 12:01 AM
big_wig_074
no,if you dont put your foot down as much there wont be as many exhaust gasses which means the turbo wont boost as high which means less power and less fuel.if you only using part throttle etc the turbo wont put out full boost like if you hammer it.
Old Jan 6, 2007 | 12:09 AM
big_wig_074
yes mate,unless you are going to be putting it in low boost mode and then booting it there! and besides you probably need to adjust the base boost pressure on the wastegate as a boost controller cannot adjust below the actuator boost pressure.can only increase it. driving at part throttle and just milling about saves a LOT of cash,especially when you dont need to shell out the silly money commanded by boost controllers!
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Russ Payne
Sep 25, 2015 08:29 PM
